servo tubing
PostPost by: William2 » Fri Jul 11, 2014 4:12 pm
Is it acceptable to use rubber servo hose for the whole length from the servo to the engine manifold or should you use nylon pipe?
William2
PostPost by: Galwaylotus » Fri Jul 11, 2014 5:25 pm
I find fuel hose makes a good vacuum hose as it's reinforced and doesn't collapse.
'67 S3 SE FHC
Galwaylotus
PostPost by: vernon.taylor » Sun Jul 13, 2014 1:20 pm
Salut
I used a short length of silicon hose from the metal pipe to the servo - about 20cm. Works fine, but I'm not sure I would use it for the whole length - it's quite supple so could possibly collapse. Reinforced-type fuel hose should be fine.
Vernon
vernon.taylor
