handbrake cable adjuster seized.......
having a bit of trouble....adjuster is rusted solid in engine mount alex had some good advice [thanks alex!]
flooded with wd40 and trying to 'work' it free, but I'm a bit scared of overdoing it and shearing it off.....I presume the use of heat in that area is a no ,no, due to proximity of fuel lines, etc..
so, anybody 'been there, done that'......?
'Never give up!....unless it's hopeless.....'
1970 S4 dhc big valve
1973 Ginetta G15
1967 Ginetta G4 [sadly now sold]
1959 lotus elite type 14
1973 Ginetta G15
- Elanconvert
I take it you have undone the locking nut?
hi john
that's seized as well!!!!
fred
fred
1973 Ginetta G15
1973 Ginetta G15
- Elanconvert
WD40 isn't much good as a release agent. Plus Gas is much better - can you still get it in UK?
Otherwise a 50-50 mix of Acetone and Auto transmission fluid, shake well, and apply in a spray bottle.
RogerFrench - Fourth Gear
thanks guys.....only just heard of plus gas, but have now ordered some from ebay.....
fingers crossed....
fred
just had a thought about getting some heat in.......how about some caustic soda wrapped in some cloth around the
threads, and a few drops of water......??????
fingers crossed....
fred
1973 Ginetta G15
1973 Ginetta G15
- Elanconvert
Soak it in cola. Perhaps wrap in a rag soaked in Coke. Always great for removing rust (much better than drinking the stuff!!!)
'67 S3 SE FHC
'67 S3 SE FHC
yeah......coke could work but maybe not so good at penetration......[no innuendo intended.... ]
fred
fred
1973 Ginetta G15
1973 Ginetta G15
- Elanconvert
ecamiel wrote:try PB Blaster penetrating oil. The best. It really works.
Eric
S1
He's over the pond, don't think it's sold there.
correct!
however, I think you CAN get some sent from USA, at a price.......
will give plusgas a try, if no luck might fork out for pb blaster ..!
fred
fred
1973 Ginetta G15
1973 Ginetta G15
- Elanconvert
This is interesting:
"The April/May 2007 edition of Machinist's Workshop did a test of
penetrating oils where they measured the force required to loosen
rusty test devices. Buy the issue if you want to see how they did the
test. The results reported were interesting. The lower the number of
pounds the better. Mighty interesting results for simple acetone and
tranny fluid!
Penetrating oil . Average load .. Price per fluid ounce
None ................. 516 pounds .
WD-40 .............. 238 pounds .. $0.25
PB Blaster ......... 214 pounds .. $0.35
Liquid Wrench ... 127 pounds .. $0.21
Kano Kroil ........ 106 pounds .. $0.75
ATF-Acetone mix.. 53 pounds .. $0.10
The ATF-Acetone mix was a 50/50 mix (1 to 1 ratio)."
tranny fluid!
'67 S3 SE FHC
'67 S3 SE FHC
got to agree......that IS interesting!
I will definitely give it a try and report back!
thanks for taking the time to do the research!
fred
fred
1973 Ginetta G15
1973 Ginetta G15
- Elanconvert
Was just about to order some acetone when I suddenly realised that is/was used for removing nail varnish/polish and if i remember rightly reacts with plastics/rubber....not wanting to spray it where it may damage flexible brake pipes,trunion bushes,fibreglass,ball-joint covers etc etc
Comments?
Comments?
Very good point and a good word of caution. As in many things in life it's horses for courses so indiscriminate use could court disaster. It could still be useful as long as it's kept away from certain materials. I guess it wouldn't be prudent to store it in an old plastic bottle!!
'67 S3 SE FHC
'67 S3 SE FHC
