Brake servo non-return valve
Salut
Your indulgence and knowledge is humbly requested:
- a mate is having trouble with his servo-assisted brakes. Being I thought clever, I told him it was because he didn't have a vacuum non-return valve between the manifold and servo. He told me there is one at the entrance of the servo (a plastic bit with a grommet - like all servos I've seen) - we took it out and tested it and he's right. So what is the in-line one for ? Safety ?
Merci.
Vernon
Merci.
Vernon
vernon.taylor - Fourth Gear
The inline non-return valve on the carburettor side, ensures that the vaccum reservoir, built into the front chassis crossmember, retains its vacuum, without a reservoir the action of the brake servo would vary dramatically depending on what the engine was doing at the time. It also ensures that the headlights don't wobble up & down depending on what the engine is doing.
I have a strong suspicion that the failure of that valve on my car (many years ago) whas what caused me to have two shunts into the back of a vehicle in front of me and made me distrust servos so I removed mine and have run without assisted brakes ever since.
The standard one on an elan is fitted on the fat rigid pipe near the steering rack, but you can easily fit one near the carburettor. Thee are some small suitable ones sold for modern fuel systems which look good for this purpose.
http://www.burtonpower.com/catalogsearc ... turn+valve
You may also have one in the T-piece connector to the vacuum reservoir.
vernon.taylor wrote:Salut
Merci.
Vernon
Salut Vernon, would that be the person posting about his brake servo with control loading spring issues?
If so I wondered whether the pulsations that he is experiencing may be down to a defective or missing valve or I have a strong feeling that the vacuum line to the servo should have a restrictor to prevent it.
- Chancer
HI
Your getting mixed up between the brake vacuum take off and the headlight vacuum take off.
The brake is at the bulkhead and the Headlights at the radiator end of the manifold, two complete separate systems.
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
Hawksfield wrote:HI
Aye, sorry, that is on the +2.
What I described is on the 2-seater Elan.
Salut les gars
D?sol? - I should have mentioned it concerns a +2 - nobody here on the forum.
The headlight takeoff has a seperate non-return valve (that works). The servo takeoff usually (I believe) has a non-return valve in the pipework near the bulkhead. My question is 'what is the function of this non-return valve' given that all the servos I've seen (about five have a non-return valve at their input. Is it a safety measure in case the servo non-return valve fails ?
Merci
Vernon
Merci
Vernon
Hi Vernon
My 73 Plus 2S 130 /5 only has the non return valve in the servo unit, it does not have one at the bulkhead intake connection for the servo like there is for the headlights vacuum connection at the front . I believe this is the standard arrangement.
Salut Rohan
Not my car but this is what I am talking about. I've seen it on a lot of cars:
Vernon
Vernon
Hmm, so no vacuum reservoir on the brakes of a plus 2. ?
In which case I expect Lotus put that one in, just in case a servo was used that had no non return valve.
It won't matter that there are two and it will be slightly safer.
The valve in that picture looks identical to the one I took off my two-seater Elan. It had completely failed. I can see daylight through it. But WHEN it failed I do not know since I ran for nearly 30 years with the servo still mounted in the car, but not connected at all.
I finally got around to taking it out 3 years ago and sold the servo on eBay.
On further thoughts, in my opinion.
The volume of the vacuum pipe from rear carb to servo is not big enough to significantly act as a reservoir for the brakes and so the non return valve would have no significant effect on braking, but perhaps it has enough volume to affect the fuel mixture. Without a valve, air would tend to rush back and forwards through the side hole of number 4 carb, causing erratic air mixture.
So putting a non return valve near the carburettor may prevent some odd misfiring situations.
HI billwill
You are probably correct for the reason to have the NR valve close to the manifold and in addition a length of tube was used. My car was originally installed like this but had to be changed because of a faulty NR in the tube was failing, I now have an inline NR in the rubber connecting pipe, as my servo does not have a NR in the inlet to the servo can.
+2s130 1971
+2s130 1971
