Egg-cup master reservoir
The master cylinder reservoir on my S4 is small and inaccessible so the first sign of a hydraulic problem will probably be no brakes. There's not much room for a bigger reservoir or a float-style level switch, so the options seem to be: optical level switch, remote reservoir or ...... Any suggestions?
- DonKearley
DonKearley wrote:The master cylinder reservoir on my S4 is small
Silly question probably but are you looking at the right reservoir ?
Assuming you have a RHD car the brake reservoir is offset inboard and not immediately behind the brake pedal....but I'm sure you knew that.
S4 DHC
S4 DHC
- oldelanman
Thanks for the help. I went through the forum discussions and ended up looking at Demon Tweeks. Found plenty of options there, so I'll pick something from them.
- DonKearley
