Brake fluid level switch. Single circuit
Can anyone suggest a level switch for the brake fluid. It is the orginal girling single circuit arrangment.
James
James
holywood3645 - Fourth Gear
Check out this thread:
lotus-suspension-f42/tandem-master-cylinder-t19064-30.html
I built a brake fluid level switch using a modified Car Builder Solutions cap. It works fine.
Nick
Nick
elanner - Fourth Gear
Sorry, I should explain. It is a non-federal spec car for the export market (shipped to Canada) Left Hand Drive. Clutch with single circuit brake Master Cylinders. The M/C's are not obstructed by Webbers. If there is a device that works with a Girling cap, that would be ideal
Thanks for the response
James
James
billwill wrote:Is there room for any kind of hydraulic fluid level switch under the carbs of a 2-seater Elan?
Plenty of room on a LHD car!!
Not sure how tight you are on a RHD car to the carbs, the aftermarket sensor maybe adds about 1/2" height wise.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
