Brakes staying on
1966 S3 single circuit brakes with servo. Brakes stick on momentarily after application then release. I thought it might be the master cylinder so I replaced it and bled the brakes, but still misbehaving. My next thought was to overhaul the front calipers as the car has been standing unused for a long while and I considered the pistons/cylinders may be corroded. But as the effect is equal I wondered about the servo as the cause? To test can I bypass the servo with a union between in/out ( and bleeding after) and test? Obviously I ll need to press harder!!
Malcolm
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Yes that is the test !
This is not an unheard-of complaint. Check the archives. And it's nearly always the servo rather than m/c or calipers.
'72 Sprint
'72 Sprint
- richardcox_lotus
I have the same problem. Should we get rid of the servo (also called mastervac?)
Cooled down by CliveyBoy!
Pistacchio sprint 72 - Fourth Gear
I took my servo out of circuit many, many years ago. More trouble than it is worth. An elan does not need a brake servo, but best to get the softer brake pads when you take it out of circuit.
I had the same problem.
Rebuilt M/C
Rebuilt calipers
Rebuilt servo
discovered that if I hooked my foot under the pedal to pull it up the last bit it didn't stick
Rebuilt M/C again
The problem persisted and operating the pedal by hand I could feel the friction of the last bit.
Oiled the pedal box - No improvement
Took the pedal box out - everything free
On re-assembly I discovered that the alignment could be altered by moving the aluminium end support bearing.
Problem solved!
Rebuilt M/C
Rebuilt calipers
Rebuilt servo
Rebuilt M/C again
Problem solved!
- AHM
mine do the same.....
I haven't found he root cause yet but suspect my servo orientation.....
if you have a Lockheed servo then check it orientation as this is know to cause 'slow' brakes....
I had posted a request for a picture in a thread called 'Lockheed servo' and Mike supplied the full fitting instructions.....
lotus-suspension-f42/lockheed-servo-t29072.html
basically the body needs to be between 25 and 45 deg 'tilt' backwards and the valve rotated approx. 30deg from horizontal (see fig 3)
I'm hoping this will solve my problems....hope it help you too
G
G
Thanks for the responses, confirms what I thought. I shall try it without the servo in the circuit. I did wonder about the need for a servo in such a light car. If necessary, as suggested, I shall try some different pad specification.
Malcolm
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Check out the search....it's a return spring in the servo...
Edit
Try
http://www.classicbrake.co.uk/
Edit
Try
Definitely the servo sticking on.
The girling remote servos are hideously expensive to replace, but a Lockheed type can be used and bought for less than ?80 on Ebay and elsewhere. Girling service kits are around ?50 including post.
If originality is not important, just remove the servo and run without it. With greenstuff or similar pads you won't notice any extra pedal effort.
Kindest regards
Alan Thomas
Alan Thomas
Hi Malcolm
If its a Lockheed Servo - I would put money on the problem arising from the 'reaction piston' sticking - small bullet looking thingy here - http://www.triumph-spitfire.nl/servoimages.htm
Clean and red rubber grease it!
englishmaninwales wrote:Thanks for the responses, confirms what I thought. I shall try it without the servo in the circuit. I did wonder about the need for a servo in such a light car. If necessary, as suggested, I shall try some different pad specification.
Malcolm
mikec2126 - New-tral
In the workshop manual, they advice its replacement every three years and recommend strongly not to dissassembly it.
I ordered a new one from Steve at sjsportscars ref SJ036J0016
Pistacchio sprint 72 wrote:In the workshop manual, they advice its replacement every three years and recommend strongly not to dissassembly it.
really
a new servo every three years.......
Users browsing this forum: mini64 and 31 guests
