Rear Brake Caliper to strut mounting bolt torque
PostPost by: bloodknock » Tue May 28, 2013 6:17 pm
Hello out there,
can someone tell me the correct torque setting for rear caliper to strut mounting, I cant find it in my manual, of course it could be senility again!
Mine uses wire locked bolts.
Bob Skerritt
PostPost by: oldelanman » Tue May 28, 2013 6:32 pm
You are right the mounting bolt torques are not listed in my manual either.
I just used the standard torque for the bolt size which I think is 7/16" UNF. In which case it's 40-45 lb/ft but I'm sure someone will correct me if I'm wrong.
S4 DHC
PostPost by: Quart Meg Miles » Tue May 28, 2013 8:05 pm
oldelanman wrote:You are right the mounting bolt torques are not listed in my manual either.
That is the correct bolt and torque.
Meg
Quart Meg Miles
PostPost by: bloodknock » Wed May 29, 2013 8:32 am
Thanks people.
cron
