Remote brake / clutch reservoirs
PostPost by: Maulden7 » Tue Mar 05, 2013 4:48 pm
Anybody have any recommendations as to the best / easiest way to fit remote reservoirs for the brake & clutch hydraulics?
This is for a standard S2 single line (non-servo) system (albeit with +2 discs / calipers at the front)
Thanks - Dave M.
Maulden7
PostPost by: rgh0 » Sat Mar 16, 2013 11:03 pm
Most of the racing car suppliers can supply master cylinders and remote rservoirs that can be fettled to fit. There have been discussion here around various other alternative master cylinders also if you do a search.
Rohan.
PostPost by: GrUmPyBoDgEr » Sun Mar 17, 2013 4:23 am
As mentioned by Rohan, the parts needed are readily available for the job here in GB; here's a photo of the job I did on my S4 a few years ago.
Engine1.jpg and
Beware of the Illuminati
GrUmPyBoDgEr
PostPost by: cabc26b » Mon Mar 18, 2013 6:28 pm
The clear plastic reservoirs look great and work fine , however being a sucker for a period look i went the metal can route .
George
girling-BR-.JPG and
PostPost by: holywood3645 » Mon Mar 18, 2013 7:02 pm
George, what MC is that?
James
PostPost by: cabc26b » Mon Mar 18, 2013 11:42 pm
James,
Its an Alloy Raybestos - 3/4" firm pedal moderate effort, I use a tilton valve to adjust bias ( within arms reach ) -
George
PostPost by: gjz30075 » Mon Mar 18, 2013 11:54 pm
George, could that mc be had with reservoirs attached?
Greg Z
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: cabc26b » Tue Mar 19, 2013 1:41 pm
Greg,
There are options for integrated reservoirs, I can't remember how this one started life though as i sourced 2 ( one with and one with out ) and fitted this one because of its port orientation which was different than option-B.
George
Users browsing this forum: mini64 and 31 guests
