LHD tandem mc brake line routing
PostPost by: lotocone » Mon May 07, 2012 9:47 pm
Does anyone have a photo of the original routing of the hard brake lines between the LHD tandem master cylinder and the steering column? I've searched the engine bay photo thread and other threads, but nothing I find shows the lines clearly.
Some old lines (probably original) that I came across seem to be bent to exit the master cylinder, then down under it, then forward along the fiberglass on the left side of the engine bay, then down under the steering column.
I'd like to follow the original routing, but I'm not very good at tube bending and an easier route would be to exit the MC and follow the top flange of the chassis without going under the MC.
Thanks for any help.
Bob
1969 S4
lotocone
PostPost by: terryp » Tue May 08, 2012 7:12 am
Bob
This may help, although I am not sure whether its original
DSCF3100.JPG and
Terry
terryp
PostPost by: lotocone » Tue May 08, 2012 11:36 am
Terry,
Thank you, your picture does help a lot. I will probably route the new lines like the picture shows. It might be a little difficult keeping a gap between the 2 brake lines in the available space, but I'll see what I can do.
Hope to be driving again before long.
Bob
1969 S4
lotocone
PostPost by: gjz30075 » Tue May 08, 2012 12:18 pm
Similar to Terry's. Both lines are individually clipped to the frame.
DSC02993.JPG and
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: lotocone » Tue May 08, 2012 12:30 pm
Thank you Greg. The angle of the picture helps and the clips are a good idea. Your restoration looks great.
Bob
1969 S4
lotocone
