S4 Hand Brake component
Hi All,
I've previously posted this in the Wanted section and seems like its one of the unobtainium bits. So here's hoping someone might have a spare or have their handbrake in bits on the bench and can sketch me one out so I can make one.
What I am seeking is the small fitting in the end of the umbrella handbrake lever that retains the outer cable. Seems quite easy to reverse engineer it but if it holds the outer cable either to long or short the adjustment is all up the spout.
Thanks in advance
Dave & Jaks
1969 S4SE DHC (nearing completion)
Thanks in advance
Dave & Jaks
Dave
Yes I know I cant spell, but can weld, spray paint, lay grp and rebuild engines.
69 S4SE DHC
Dave
69 S4SE DHC
- DaveAlmey
DaveAlmey wrote:Hi All,
Thanks in advance
Dave & Jaks
There are two types of hand-brake lever, one with a white release "button" and one which twists to release. Which one do you have?
I think there are photos somewhere on here already but I'm usually mistaken.
Pete.
http://www.petetaylor.org.uk
Pete.
Dave, I've got the twist-to-release type on my Sprint and the end of the housing has a piece that was brazed on with a nut to hold a small set screw. The set screw holds the outer sheath of the handbrake cable. Hope this helps
Greg Z
Greg Z
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
