Rear brake pads
PostPost by: Bluefield » Wed Nov 16, 2011 5:16 pm
Greetings,
I need to get new rear brake pads - should I go for standard or upgraded? green stuff? Might as well get new front ones as well. What's your experience? Yes, I have used the search function to look at older posts but thought it would be good to post this up again..
/Bluefield
26-3811
Bluefield
PostPost by: rgh0 » Thu Nov 17, 2011 10:20 am
I have found Greenstuff or similar high coefficient of friction pads in the front combined with standard style pads ( eg blackstuff from ebc) work well and improve the brake balance as with modern tyres that have more adhersion than orginal the cars have too much rear brake and lock up rears well before the fronts. The lower coefficient of friction rears compared to the front get the balance better.
PostPost by: peterako » Thu Nov 17, 2011 11:43 am
With a lot less high performance driving in my Elan (+2) than Rohan in his Elan(s) :) ...
I 100% agree.... Green on the front and standard on the back.
Nice balance and extremely good in the dry.
In the wet....well a light car and grease roads :shock:
But driving is adjusted according :D
Peter
'73 +2S 130/5
peterako
PostPost by: Paul Chapman » Fri Nov 18, 2011 10:23 am
I have recently changed disc's and pad's all round this year using ECB products, good quality parts & excellent service and I also went for standard material for the rear pads and green for the fronts. Once eveything had bedded in the brake performance is very good.
It is also worth just checking with a DTI the run out of the disc's, I had to shim one side at the rear end to get it to run true.
Paul
Paul Chapman
PostPost by: Bluefield » Fri Nov 25, 2011 12:48 pm
I guess one can conclude that green + blacks are the ones to go for then :)
By the way, from where did you buy your stuff? ECB directly? Paul Matty? Moss? As I have more to order, one might as well try to buy where it's cheaper...
Bluefield
PostPost by: Paul Chapman » Mon Nov 28, 2011 9:09 am
I got the full set of disc's & pad's direct from EBC for about ?175, 48hr delivery, all items listed on thier Website.
Paul
Paul Chapman
