Handbrake switch and Hazards
I'm missing a handbrake warning light switch on my '68 plus 2. I have the amber light in the dash but no switch on the lever. Can anyone suggest a suitable replacement part and provider based in the UK? I've tracked down the original part I need from RD Enterprises site but I assume the Lotus part is no longer available?
Part 22?
http://rdent.com/manuals/plus2/brakes/JF.gif
Lotus part number 036M6030
I'm also on the hunt for a suitable Hazard light kit as mine didn't have it as standard. I've seen a few kits around, but does anyone have any experience or recommendations? I have a spare hole in the steering column which I was going to use for the pull toggle. Is this straight forward to fit?
Ian
Part 22?
Ian
Iyarno - Second Gear
Sue Miller found me a used handbrake switch for my S3 which is fine. I have also seen them on Ebay sometimes. Keep looking, it will turn up.
Eric in Burnley
1967 S3 Type 45
Eric in Burnley
1967 S3 Type 45
- ericbushby
There are two on ebay now if you don`t mind buying from the states. Look under `handbrake switch`.
they are listed for Jaguar E Type, but they look right to me. Does anyone know if this is definitely the same switch.
Hope this helps
Eric
67 Type 45 S3 SE now running.
Hope this helps
Eric
- ericbushby
Not a +2 owner but I have been looking for the same parts for the elan.
I believe this may be the handbrake switch
http://www.ebay.co.uk/itm/Lucas-SMB422- ... 2eb7deb424
and this the warning light
http://www.ebay.co.uk/itm/Lucas-SPB357- ... 2c5fbfb54b
Simon
Simon
- AHM
My handbrake switch wires were always being knocked off by my feet. The switch protrudes downward and is vulnerable.
After many attempts to secure the wires with nylon wire ties, I soldered a wire to each switch terminal and crimped Lucas bullet terminals to the other end. Connected it with "single" bullet connectors.
Works well ...so far.
You might wish to do this when installing.
Bob
Bob
- rdssdi
Thanks Bob, which Jag company do you mean?
All these parts companies keep appearing, and I thought I knew most of the places in the UK. Maybe it would be good to get a thread started which lists all the classic car part suppliers. A name, URL and which bit of the Lotus they are useful for...a sort of Lotus social bookmarking...
Or has that been done already?
Ian,
How about this one: http://www.holden.co.uk/displayproducts ... t+Switches
Colin.
Colin.
Iyarno wrote:I'm missing a handbrake warning light switch on my '68 plus 2. I have the amber light in the dash but no switch on the lever. Can anyone suggest a suitable replacement part and provider based in the UK? I've tracked down the original part I need from RD Enterprises site but I assume the Lotus part is no longer available?
Part 22?
Ian
'68 S4 DHC
- fatboyoz
Handbrake light switch is Lucas part no SMB479 available from http://autoelectricalspares.co.uk - cost around ?20
tim22 - First Gear
