REPOSITION HANDBRAKE LEVER
I've seen many +2s with the handbrake lever in the central position but only one Elan with this conversion. Has anyone on this forum done such a thing to an Elan?
I found using the handbrake impossible when the car had fixed seatbelts, and still very difficult and uncomfortable even with retractable belts fitted. So it would be more than convenient to do such a conversion.
I am more than capable of working out how do do such a thing, but thought it prudent to ask just in case there are some pitfalls.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
Brian,
Are you sure the cars you've seen weren't spyder zetec chassis with a central handbrake lever? My zetec chassis S4 elan has it but never seen a conventional twink elan with such a thing....You'd have to do a fair amount of work to the chassis to mount a central handbrake lever otherwise.
Mark.
Mark.
- Mark B
Mark B wrote:Brian,
Mark.
I agree....
there is only the spyder chassis which I know of which is 'prepared' to take a central handbrake......
mmmmmmm angle grinder on the chassis with glass fibre body still on could be 'interesting'
Mark B wrote:Brian,
Mark.
As I said, I've only seen one Elan with a central handbrake lever and it certainly was not a Spyder Zetec job.
I'm now searching the archive files following what Gerry said.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
I`ve done it, Mrs. Jim wouldn`t drive the car otherwise, and it was quite simple. I bought an ordinary, slim, handbrake from ebay and bolted it to a plate with a lip on the bottom. The plate was bolted through the lip, floor and the chassis, tight between the seat and the central tunnel. To gear up the action I have a simple lever hinging off the diff. tie rod stud with the cable from the new handbrake lever operating it about 1" up and a rod higher up the lever, about 3", connected to the existing tree. The original mechanism and cable remain in situ with the old cable taped to the wishbone for a (very) quick return to originality.
Simples.
Mr. Jim
Simples.
Mr. Jim
- jimj
jimj wrote:I`ve done it, Mrs. Jim wouldn`t drive the car otherwise, and it was quite simple. I bought an ordinary, slim, handbrake from ebay and bolted it to a plate with a lip on the bottom. The plate was bolted through the lip, floor and the chassis, tight between the seat and the central tunnel. To gear up the action I have a simple lever hinging off the diff. tie rod stud with the cable from the new handbrake lever operating it about 1" up and a rod higher up the lever, about 3", connected to the existing tree. The original mechanism and cable remain in situ with the old cable taped to the wishbone for a (very) quick return to originality.
Simples.Mr. Jim
Jim,
Pictures. pictures, pictures.......................PLEASE
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
Simples.
Mr. Jim
sounds like an MG (or simlar) handbrake where its down the side of the tunnel
Id like to see the pics too......
the MG has a rounded tunnel so you can get your fingers in......how did it work on the elan
When I bought my S3 I had difficulty in reaching the handbrake so I made a bracket to move the handle 3" nearer to the s/wheel. I can now use the handbrake with my static belt. If you decide to fit a lever between the seats it is probably easier to use if the lever is fitted to the passenger side of the tunnel as in the early sprites and midgets.
Mac
Mac
- elanmac
Paul Matty has a rallyprepared S3 FHC for sale, with a "conventional" handbrake lever. Maybe from a Mini ??
Christian - 1965 Elan S3 FHC (being restored)
HolmDenmark - First Gear
Slightly off topic but does anyone else have the problem of the lap belt part of the three point belt riding up above your hips due to the seat side rails? I do wear the belt but I'm always worried that if it's needed it can cause more damage to me than not wearing one as the belt positions itself over soft tissue rather than the structural hip bones.
'67 S3 SE FHC
'67 S3 SE FHC
jimj wrote:Pictures I have, the ability to reduce them for Elan.net, I don`t have. PM your email address and I can send them.
Jim
Irfanview is freeware that enables quick and easy re-sizing and reconfiguration of most any image file.
Jim
Temporarily Elan-less
summerinmaine - Third Gear
