long brake line
JR44 wrote:can somebody tell me where the brake routes at the back of the chassis is it inside the chassis at the diff or the outside of the chassis ??
With a standard Lotus chassis it runs underneath the backbone. You will find tabs or clips spot welded to the underside of the backbone intended to capture the brake line. From the engine bay the line passes through one of the lower holes in the front bulkhead of the back bone section. At the rear the line turns up and passes through a hole near the differential.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
