Source for S2 Front calipers
Hi all
I'm new so be nice. I sent my front calipers off to be restored and looks as if UPS has lost them. They were insured , but I can't seem to find any front calipers for sale anywhere except Lee Chapman's and those are 26R. Does anyone know of a source for these. Thanks.
Frank
Frank
66 S2 26/5194
LP4711LA-B
LP4711LA-B
ftsoft - Second Gear
They're Girling Type 14LF calipers, and either side-entry or top-entry will work. I believe the S2s were side-entry, from some Fords, whereas later cars had top-entry from Mk 3 and Mk 4 Spitfire (possibly also Herald).
Both seem to be increasingly hard to get hold of, but I got some on Ebay a couple of years ago.
There's a pair of the top-entry ones on UK Ebay now (where are you?):
http://cgi.ebay.co.uk/BRAKE-CALIPERS-RE ... 286.c0.m14
Not cheap, I think the market price has doubled since I got mine.
Paddy
Paddy
1963 Elan S1
paddy - Coveted Fifth Gear
I don't know about a 14F.
The S2 ones (side entry) are listed (see GGLG site at http://gglotus.org/ggpart/elanxref.htm#brakes) as:
2, 3, 4 to 9/71 Front Caliper, LH Girling 64032149, Cortina 10/64-10/66; Cortina MkII (not GT), Morgan +4
2, 3, 4 to 9/71 Front Caliper, RH Girling 64032150, Cortina 10/64-10/66; Cortina MkII (not GT), Morgan +4
Probably not too many of those breaking in Ohio You'll probably have more luck with the top-entry Triumph ones.
Paddy
Paddy
1963 Elan S1
ftsoft wrote:The calipers on ebay that were referenced look close, but I'm not sure what you mean by side entry or front entry.
The ones shown on Ebay are top-entry, where the hose is attached to the top of the caliper (where the red bung is).
However, on the photo you will also see a boss in the casting in line with the centre of the piston: with the "side-entry" calipers this is where the hose attaches.
Paddy
1963 Elan S1
Paddy
I just removed these calipers on Friday. I'm almost positive that the hose attaches at the top(I had a lot of issues with ALL of the bolts, so I remember this pretty clearly) . So I guess if the attaching bolts are right it could work. I sent the seller a quesion anyway. If I remember right the S1 takes a different caliper from the 2,3,4. Is that right?
Frank
Frank
66 S2 26/5194
LP4711LA-B
LP4711LA-B
ftsoft wrote:elancoupe
I'm not in a big hurry. The caliper rebuild was a first step to getting the car mobile so that I can rebuild the water pump. Could you tell me more?
Frank
These are type 14 LF. I sent you a PM.
Could also take a picture if need be.
- elancoupe
Frank, my S2 calipers are top entry but it is an early S2, the early S2's had a lot of S1 parts on them the calipers being one of parts, I believe the the later S2's had a slightly larger caliper piston than the S1's and probally side entry brake hose.
Thanks. My Elan is in the middle of the s2's. It's really a 66, just registered as a 67. I'm pretty sure my calipers are top entry also. I followed the link that Paddy gave and those calipers appear identical to mine. Unfortunately I haven't found any specs on them (14LF?).
Frank
Frank
66 S2 26/5194
LP4711LA-B
LP4711LA-B
The calipers will be marked "14L". If you want to be certain they are right, then you can check the casting number on the caliper; the part number itself isn't shown anywhere. The ones you're after have a number cast adjacent to the mounting lug of 64327863. However, if they're Type 14 and off a Triumph Spitfire or Herald, I'm pretty sure they wil be right. (Just for reference, the Type number is the piston diameter in 1/8", so Type 14 is 1.75", Type 16 is 2", etc.)
(Apparently there was a slightly different caliper, with an incompatible fitting, fitted to an Avenger, which was also marked "14L" but had a different casting number, 64327544.)
Paddy
Paddy
1963 Elan S1
