any help with brake light switch?
PostPost by: lotusdelta » Fri May 01, 2009 6:51 pm
Can anyone tell me where the switch might be that activates the brake lights?. I have turn signals,driving lights, and have current to the light assemblies. I have replaced all bulbs so I know that not it. Is there a pressure switch somewhere near the master cylinder perhaps?....any help would be appreciated
David
72 Lotus Elan Sprint Coupe
usa federalised
72 elan sprint coupe
lotusdelta
PostPost by: Jason1 » Fri May 01, 2009 6:59 pm
On my early +2 it is a pressure switch mounted into the 3 way split in the brake pipe. You can see it if you look through the right hand front wheel arch. It looks like the pic attached.
On the later +2 the mechanical switch is screwed into the rear of the pedal box and can be viewed from the engine bay.
Hope this helps
Jason
Jason1
PostPost by: oldelanman » Fri May 01, 2009 7:18 pm
On my S4 it's a mechanical switch operated by the lever on the LH end of the pedal shaft inside the car. See pics.
Pedal box assembly.jpg and
Pedal box assembly 003.jpg and
S4 DHC
PostPost by: lotusdelta » Fri May 01, 2009 7:43 pm
jason and rodger,
My thanks for your help...i ask a question and not only get an answer but with pictures as well...I love this site...what a great resource.
Will check the switch as soon as i can figure out how to wriggle under the foot pedals and have a look.
thansk everyone,
david
lotusdelta
PostPost by: Jason1 » Sat May 02, 2009 3:57 pm
Couple more pics for you:
Late pedal box arrow points to where the mechanical switch screws in.
Couple of pics through my wheelarch of my early +2 hydraulic switch.
Jason
DSCF2306.JPG and
DSCF2307.JPG and
DSCF2305.JPG and
Jason1
