Handbrake Clamping Levers
PostPost by: carrierdave » Wed Nov 21, 2007 10:54 am
Hi all,
Has anyone removed both the inner and outer handbrake clamping levers from the rear brake calipers?
At the moment I can not see how it can be done apart from drilling out the pin and then replacing it. :?
Any assistance would be greatfully received.
David
carrierdave
PostPost by: garyeanderson » Wed Nov 21, 2007 12:04 pm
Hi David
If you clean the caliper parts real good, you will notice that the pins (that the levers pivot on) are internally threaded to except a 10-32 rod or bolt . If you screw a threaded rod in the pin with a nut, a washer, and a deep socket that is larger than the diameter of the pin, the pin will be pulled out as you tighten the nut. You may want to add some heat to help it along...
Gary
garyeanderson
PostPost by: carrierdave » Wed Nov 21, 2007 12:44 pm
Thanks Gary. I am sure there was a previous thread on this some time ago but i couldn't find it.
I will give it a go and keep my fingers crossed.
Dave
carrierdave
PostPost by: CBUEB1771 » Wed Nov 21, 2007 8:51 pm
I use a small slide hammer for extracting these pivots. I made a small adapter for the slide hammer that holds a long 10-32 set screw which is screwed into the pin. Clean everything well first as Gary says and the pins will come out fairly easily.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
PostPost by: carrierdave » Thu Nov 22, 2007 11:47 am
Hi all,
The first one came out pretty easily; the second one is still in there. I will need to drill a bit deeper and then cut out a longer thread to have a better chance of removing it.
I do like the idea of a slide hammer.
Dave
carrierdave
