Brake Servo
Noticed last night that the rubber pipe / grommet on suction side of brake servo has split and actually fell out (this is one closet to thermostat housing). I've attempted a temporary repair with super glue and it appears to be holding. Doe's anyone know if its possible to buy this bit separately or is it a new sevo job?
- Phil W
I'm not sure if you have managed to get hold of one but give these a call
http://www.jlspares.co.uk/index.htm
Good luck
Dave
Good luck
Dave
- carrierdave
Hi Phil,
I recently refurbished by brake servo with a kit from J&L. I may have the old elbow in my garage somewhere ? I will see if I can find it.
The only problem with replacing the elbow is that there is a nylon plug that needs to be inserted from inside of the drum or shell to hold the elbow in place.
I did manage to remove the outer ring clamp from my servo by cutting through the spot weld; I was intending to reuse the band by welding it band back together. In the end I used the new clamp supplied with the kit.
I?ll see what I can find and let you know.
David
David
- carrierdave
