Reasssembling Rear Brake Discs
PostPost by: Jens » Sat Apr 16, 2005 9:37 pm
What is the easiest way to put brakediscs back on again. I have spent the entire evening out in the garage cursing the i**ot that took them of in the first place as it is one hell of a job to get them back on. When all my knuckles were bleeding I quit for today, now I am wondering how to do it in the least painfull way. Any suggestions? My car is not fitted with U-joints.
Thanks.
//Jens
"Make the suspension adjustable and they will adjust it wrong - look at what they can do to a Weber carburetor in just a few moments of stupidity with a screwdriver..." (CABC)
My one problem is that distance keeps me from my Elan. (36/5395)
Jens
PostPost by: rgh0 » Sun Apr 17, 2005 9:35 am
Jens
I presume your problem is getting the disc over the 3 legged spider without it fouling on the lower A frame. With the strut at full droop this can be a problem, it helps to jack up the strut. Altenatively you can remove the A frame at the outer end and drop it down out of the way until you have the disc fitted.
Users browsing this forum: No registered users and 57 guests
