Brake pads
PostPost by: Jerome » Fri Jun 30, 2006 9:19 am
I'm a french owner of a +2S 130/5, it's a pleasure to discover this forum, there are a lot of usefull informations.
I need to replace my brake pads. Do you know from which car come the rear pads (triumph Herald ?) , because I would like to find it in France.
I've still new front pads and ordering in UK just for rear pads 'll be expensive....(pads + vat + postage...)
Thank you in advance
Jerome
Jerome
First Gear
First Gear
PostPost by: ppnelan » Fri Jun 30, 2006 9:35 am
Welcome Jerome :!: :D
The rear pads are special to the Elan and +2. The rear brake caliper assemblies are not used on any other vehicle, which is why they are 'expensive'...
Best wishes,
:arrow: Matthew
ppnelan
PostPost by: Jerome » Fri Jun 30, 2006 10:13 am
thanks for your quick answer.
The postage cost only for pads become expensive in regards of the pads cost (17.50? at C Neil or 17? at SJ'S) that's the reason why I was looking for interchangeability.
I use to buy all my parts at TTR and PMatty, so I don't know a good dealer in France (crossing the chanel increases the prices...).
regards
Jerome
Jerome
First Gear
First Gear
PostPost by: rgh0 » Fri Jun 30, 2006 11:59 am
Get new linings bonded onto your existing back plates or cut down a similarly shaped pad to fit using your existing pads as a template if the price of new rear pads is excessive for you.
Make sure the quality of either option is spot on, its embarrassing if they dont work. Be careful about the dust generated when cutting down pads, while no asbestos in them these days I am sure it does you no good to breath it in high concentrations.
regards
PostPost by: Jerome » Fri Jun 30, 2006 12:31 pm
Unfortunatly, french people aren't fond of Elan, parts for Elan are very rare even in high concentrations.
I'll ask my "garagist" if he knows a good solution (relining, cutting down...)
But I think I'm going to be resignated to order new rear pads at PMatty, I'll found other parts to order with.
Thanks a lot
Jerome
Jerome
First Gear
First Gear
PostPost by: types26/36 » Fri Jun 30, 2006 1:36 pm
I need some rear pads myself but looking through the sites I can not find rear EBC green pads, do they only make "Green Stuff" for the front?
I'm going to Matty's this weekend so I will see what he keeps.
types26/36
PostPost by: tdafforn » Fri Jun 30, 2006 2:17 pm
Yep,
Only EBC black stuff for the rears..
tdafforn
PostPost by: tonycharente » Wed Jul 05, 2006 6:19 pm
Jerome,
There's a French on-line EBC stockists that lists the old Elans and Elan+2's - for a +2, see:-
http://www.automotostop.com/index.php?p ... odele=3062
I haven't used them yet - please let me know how you get on!
Salut
Tony
1969 Elan FHC S4 SE
tonycharente
PostPost by: Jerome » Thu Jul 06, 2006 8:33 am
Merci Tony
I just realize I need to replace the A Frame bushes, so I'll order at Paul Matty.
J?r?me
Jerome
First Gear
First Gear
