1969 Elan S4 Tandem Master Brake Cylinder Question
PostPost by: Mazzini » Wed Nov 09, 2016 9:03 am
If it's of any interest, I have three Federal Elan Tandem MC's, at least two are new - one of the two was reconditioned by Classic Car Automotive.
Drop me an email if your interested, if not I'll post them on eBay.
PostPost by: pharriso » Fri Jun 28, 2019 8:07 pm
Postscript: I have just figured out that Glen's original can is not home made at all - It is the original fitment on S2 Europa's from unit #2089 & is shown in the parts book:
ebay_machinedsovycan_012018_europas2_partsmanual.jpg and
I actually found a NewOldStock part on eBay last year, here it is shown side by side with the Elan SOVY:
img_1006.jpg and
I believe the old SOVY reservoirs were converted touch up paint tins, they were probably discontinued & Lotus had no choice but to manufacture the cans from Solid stock.
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: Certified Lotus » Fri Jun 28, 2019 10:12 pm
Phil, that is very interesting to know. Now if I can just remember what I did with that solid stock can.......
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Certified Lotus
PostPost by: 1owner69Elan » Fri Jun 28, 2019 10:24 pm
Having my original Sovy can and top constantly leak, from day one, I have now adapted the billet reservoir from Wilwood (shown below). I am using a modern indicator reservoir top, that connects to the brake fail dash light, same as stock. No more leaks, for the first time in 50 years.
At some point I may adapt the original red Sovy top to the billet cap to provide a more original look.
'69 Elan S4 SE
Street 181 BHP
Original owner
PostPost by: Sea Ranch » Fri Jun 28, 2019 10:35 pm
Hello, Original Owner!
Very interested in your inventive solution. Especially the Wilwood part number, how you adapted it to the master cylinder and the modern indicator reservoir top which signals the dash light.
Would appreciate any pix and/or further descriptions/explanations. Thanks so much!
Randy
1970 Elan Plus 2S
Sea Ranch
PostPost by: 1owner69Elan » Fri Jun 28, 2019 11:33 pm
The Wilwood part no: 260-12696 for the canister
Part no. 330-12646 for the indicator float cap.
I think I got mine from Summit Racing.
Essentially, to adapt this:
1. Drill a hole in the plastic tandem reservoir cap. These caps are readily available. If you have an original cap, that was attached to the Sovy, with a hole in it that is in decent condition you could probably use that as well. Problem with the original cap is finding a nut that will fit in the underside recess. I opted for a new cap.
2. Secure the Wilwood reservoir with a fiber/leakproof washer and nut to the underside of the cap. If you have an original tandem reservoir there is a baffle between the two chambers of the tandem reservoir that may interfere, so you may have to fiddle things for clearance. I found a NOS tandem reservoir to replace my yellowed, original one. The NOS one has a cutout on the baffle, unlike my original one, that provides clearance for the Wilwood nipple.
My car is currently out of pocket, in for paint, so these are the best pictures I have on hand of the installation:
img_8422.jpg and
img_8419.jpg and
'69 Elan S4 SE
Street 181 BHP
Original owner
PostPost by: Sea Ranch » Fri Jun 28, 2019 11:51 pm
Thank you very much, sir! That fills in the gaps for me. Much appreciated :)
Randy
Sea Ranch
PostPost by: pharriso » Sun Jun 30, 2019 1:50 pm
1owner69Elan wrote:Having my original Sovy can and top constantly leak, from day one, I have now adapted the billet reservoir from Wilwood (shown below). I am using a modern indicator reservoir top, that connects to the brake fail dash light, same as stock. No more leaks, for the first time in 50 years.
wilwood_sovy.jpg and
1Owner69Elan - I really like what you have done there, it's a combination of the billet style container (does not rust) with the better sealing of the OE can type container
Like you I have always had difficulty sealing the SOVY canister to the nylon reservoir. Finally had success with using a large bead of Elring Dirko (aka Rohan's magic seal) on the sealing face of the Europa billet can:
0260k_europas2_sovysm.jpg and
Current SOVY configuration
Phil Harrison
PostPost by: Bobzilla » Sun Feb 18, 2024 4:13 am
What is the sovy master cylinder bore size?
With our a servo.
My brake pedal is pretty hard
Bobzilla
New-tral
PostPost by: umbyfer » Fri Jun 21, 2024 2:37 pm
i am kindly asking the correct wiring for the sovy device; i have to rebuild the missing wiring; the black wire is the ground; the red wire where is connected? to the warning light on dashboard? to the fuse box? and the warning light how it is connected? thank you.
Umberto Ferrari
Modena - Italy
Elan Sprint 7108000193K
Elite SII #1319
umbyfer
PostPost by: umbyfer » Fri Oct 04, 2024 5:05 pm
any north american could check in the garage if there is a dual Girling brake master cylinder LHD, internal bore 0.70" ? i am looking for one, also used or not usful to be repaired...
For Lotus elan sprint federal LHD '71.
thank you.
Umberto Ferrari
Modena - Italy
Elite SII #1319
umbyfer
Previous
