1969 Elan S4 Tandem Master Brake Cylinder Question
PostPost by: Certified Lotus » Tue Nov 10, 2015 11:43 pm
Phil, nice to know that you've been storing parts for me all these years :mrgreen: Hope I can repay you one day!
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Certified Lotus
PostPost by: pharriso » Wed Nov 11, 2015 12:41 pm
Glen, here is what I have:
IMG_3609.JPG and
IMG_3612.JPG and
IMG_3610.JPG and
IMG_3611.JPG and
As you can see there is some surface rust on the top edge. What I did on my renovated unit (from Terry P) was sand blast then zinc coat. It's only been a year but it still looks like new.
I'll send a PM
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: Certified Lotus » Thu Nov 12, 2015 11:41 am
Exactly what I am looking for Phil. PM responded to. Thanks once again for having a part I need !
Glen
Certified Lotus
PostPost by: oldchieft » Thu Nov 12, 2015 1:16 pm
Just a thought, I this day and age a cylinder with a male thread one end and female thread the other can be 3D printed?
If it was done in translucent plastic it would have a visible fluid level. I would bet Certified Lotus would have contacts that would know how.
Jon the Chief
oldchieft
PostPost by: Certified Lotus » Thu Nov 12, 2015 1:43 pm
Jon, your reading my mind. I needed an exact sample to scan ;-)
Glen
Certified Lotus
PostPost by: oldchieft » Thu Nov 12, 2015 2:09 pm
Wow!
That's a bit spooky!
Jon the Chief
oldchieft
PostPost by: Sandals man » Mon Nov 16, 2015 4:29 pm
Hello everybody,here the sandals man from holland.My federal elan chassis 8859 has also the tandem brake cylinder with this sofi system.Does anybody know how I can remove the fluid reservoir from the steel cylinder.I removed the 2 srews but I can not get it out.Must I use more power?
Willem
Sandals man
First Gear
First Gear
PostPost by: gjz30075 » Mon Nov 16, 2015 6:51 pm
Yes. It's a snap fit into the master cylinder and will require some prying.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: nmauduit » Tue Nov 17, 2015 1:42 pm
there is a ring clip inside the front hole of the tandem master cylinder, holding the plastic tank on; I sort of remember having seen a manual stating that for removal one should turn it 45? and pop if off, but I found it rather hard (the plastic tank is 50 years old and getting just like myself, not as flexible as I used to be). Then I found a rubber gasket sealing the front feed to the master cylinder, probably cylindrical (or what was left of it), something that was not in rebuilt kits I've seen so far... it's a non pressure gasket, yet if leaking you empty out the whole thing. The front tank feed has a conical fit to the master cylinder, but if there is some play (and the tank plus sovy make for quite a lever to hit over the years) that may not be sufficient to ensure sealing... For a tighter hold I've added a rislan tie around, clamping down the plastic tank onto the master cylinder.
S4SE 36/8198
PostPost by: mariodschy » Wed Nov 18, 2015 1:13 pm
gjz30075 wrote:Yes. It's a snap fit into the master cylinder and will require some prying.
Here is a picture, i am also looking for a metal canister if anyone has one to much please let me know...
img_6747.jpg and
I fixed it with a o-ring, an cuted the platic
img_5996.jpg and
Removing the tank was a very hard job
- 1972 Lotus Elan Sprint LHD/DHC
- 1962 Austin Healey Sprite MK II - Sold 09.05.2016
Sorry for my bad survival English ;-)
mariodschy
PostPost by: nono17120 » Wed Nov 18, 2015 8:21 pm
nmauduit wrote:I don't know if the cork is original, if it is it is enclosed in an aluminum tube on mine :
tu utilises du silicone ?
nono17120
PostPost by: nmauduit » Wed Nov 18, 2015 9:32 pm
yes, Dot 5 Automec (260?C boiling temperature)
S4SE 36/8198
PostPost by: umbyfer » Tue Nov 08, 2016 8:49 pm
Hello, really interesting that topic! In my Sprint Federal there is the warning light brake fail on the dash, but the sovie device with red cap is not present. It was removed from previous owners. If anyone of you is able to help me to find one I appreciate a lot. Thank you.
Umberto Ferrari
Modena - Italy
Elan Sprint 7108000193K
Elite SII #1319
umbyfer
PostPost by: nmauduit » Tue Nov 08, 2016 10:09 pm
umbyfer wrote:Hello, really interesting that topic! In my Sprint Federal there is the warning light brake fail on the dash, but the sovie device with red cap is not present. It was removed from previous owners. If anyone of you is able to help me to find one I appreciate a lot. Thank you.
if you're only missing the red cap with contacts, you can make one up by shortening the tube of a Jaguar E type sovy white cap... as for the reservoir tin extension if you're missing that also, I've seen some alloy replacements that had been machined, though they do not come by very often. It's a no pressure part, but that still needs to hold the fluid.
I'd be happy to find a decent tin reservoir myself...
S4SE 36/8198
PostPost by: Certified Lotus » Tue Nov 08, 2016 10:30 pm
RD enterprises sells a reproduction of the cap for $61 US. A real deal from my perspective. I have an original plus the can that I bought as a spare after finding out how difficult they are to find. Let me know if your interested, it's more expensive than RD but I'll sell for what I paid for it.
Glen
Certified Lotus
PreviousNext
