Plus 2 front calipers for Elan S1
PostPost by: paddy » Mon Dec 12, 2016 12:00 pm
toomspj wrote:I'm lucky enough to have successfully raced an Elan S1 using standard calipers and discs
I assume here when referring to "standard" calipers on an S1 you're thinking of type 14 calipers on standard discs instead of the original type 12?
Paddy
1963 Elan S1
paddy
PostPost by: toomspj » Mon Dec 12, 2016 10:21 pm
Hi Paddy
Yes type 14 - I meant standard as in standard for an Elan.
Paul
Turning money into noise!
toomspj
PostPost by: Davidb » Tue Dec 13, 2016 3:43 am
This has been a oft discussed subject on this forum:
lotus-suspension-f42/elan-brake-upgrade-t14121.html
'65 S2 4844
PostPost by: Davidb » Tue Dec 13, 2016 3:51 am
I have just been offered a set of what are apparently new old stock Girling calipers-2 AR and 2 NR for $1800.00 US This is too much for me with my conversion to Canadian dollars but perhaps a US member can benefit. Worth considering that the NR caliper requires the correct 26R magnesium rear upright with 3.5" mounting for the NR calipers though.
Contact for the calipers is Ron at raintreehandyman at gmail dot com
'65 S2 4844
PostPost by: Davidb » Fri Dec 16, 2016 4:18 am
Another thread from the past on fitting GT6 calipers. As others point out in this thread-we sure miss Gary Anderson!
lotus-suspension-f42/gt6-brakes-revisited-t19846.html
'65 S2 4844
PostPost by: bill308 » Fri Dec 16, 2016 3:03 pm
DBE can supply special NR calipers that bolt directly to standard bearing carriers. They can also supply AR calipers that work with +2 discs.
Bill
bill308
PostPost by: CBUEB1771 » Fri Dec 16, 2016 5:35 pm
Davidb wrote:\As others point out in this thread-we sure miss Gary Anderson!
I can only do so much, here is Gary (leftmost) at the vintage races at Lime Rock in September. Clark Lance and Carl Whitney also in the photo.
img_0205.jpg and
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
Previous
