+2 Dual circuit master options
PostPost by: crypto » Wed Sep 14, 2016 7:22 pm
I understand there is no space below in the +2. However yo would need about 23mm below the lowest point of the flange to get straight away using a banjo bolt
2016-09-14-21.10.14.jpg and
The really good drivers have the bugs on the side windows (cit. Walter R?hrl)
crypto
PostPost by: mbell » Wed Sep 14, 2016 8:17 pm
I can't find a good photo but I think there is only a few mm space at the mounting end and upward slope that closes the gap toward the rear of the master. I know I can't get my fingers under the master. So I believe that master will not fit, even with no fluid connections fitted! Will see if i can get a photo but believe any kind of bottom connection master is out of the question.
The triumph past supplier responded we a very unhelpful "I?m sorry but we do not offer the part you have requested." with out any reference back to what they don't offer, a reservoir a none slopping master reservoir a master for a Lotus Elan +2 (which I didn't ask for) etc....
PostPost by: Lyn7 » Thu Sep 15, 2016 7:48 am
Hi Mark, if you are looking for a new Spitfire master cylinder I bought mine from an E Bay supplier. I could probably confirm which one if it is of help? I never enquired about another resevoir and would not be too optomistic about the availability. There appears to be a lot of different resevoirs with different hole centres and sizes and fittings! If you do find one I would be delighted to know the source :D . Cheers , Lyn... :)
Lyn7
PostPost by: mbell » Thu Sep 15, 2016 6:44 pm
Thanks Lyn, there not problem getting hold of the master. It's the flat reservoir or alternative master they aren't available.
If I do find an alternative reservoir I will let you know.
PostPost by: prezoom » Thu Sep 15, 2016 7:44 pm
Mark,
I have no problem with you posting the photos of my modified Datsun 1200 master cylinder.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
prezoom
PostPost by: mbell » Thu Sep 15, 2016 8:35 pm
Thanks Rob. Here are the pictures & description of the mod provided to me by Rob/prezoom.
prezoom wrote:The bottom feed bulges will not clear the foot well without mods. What I did was cut them shorter and removed all the bottom feed parts. The rear brake feed needs to be shorter than the front. After cutting them dowm, I bought 2 16mm- 1.5 bolts and a couple of copper sealing washers. The threads do not go deep enough, so I bought a 16-1.5 bottom tap fro MSC. Not expensive. Tapped them as deep as I could go. You will have to shorten the 2 bolts in order to get clearance for the AN 3-1/8" pipe adapters to fit in the sides of lower portion. I also removed the bench bleed fittings and plugged them with 1/8" plugs.
20160805_100526_resized_1.jpg and
20160805_100352_resized_1.jpg and
PostPost by: fatboyoz » Fri Sep 16, 2016 5:57 am
Hi Mark,
Here is another M/C for consideration. Not cheap, and I do not know the size of the bore. It's for a Europa with the dual braking system. http://www.sjsportscars.co.uk/index.php?mod=10
Colin.
'68 S4 DHC
fatboyoz
PostPost by: mbell » Fri Sep 16, 2016 6:35 pm
Thanks Colin. I'd got in my head the Europa had a 0.75" master not 0.70" but now not sure about that. Interesting that it's not listed against the +2 if it is 0.7".
You're right about not cheap I am probably looking at $250 to get it here. The spitfire is $70-80, so it's a big difference. I am getting very close to pulling the trigger on the spitfire unit....
PostPost by: m750rider » Wed Sep 21, 2016 7:17 pm
I think I have a complete Girling Tandem master cylinder including the reservoir. If anyone is interested let me know and I'll go search for it in my parts bin. I'm sure it would need a seal kit and rebuild to be serviceable.
Bob
1969 S4 SE
45/8842
m750rider
PostPost by: The Veg » Wed Sep 21, 2016 11:12 pm
Bob, is that the same Girling that Mark had at the top of his list? I may be interested; are rebuild parts easily available?
2012 BMW R1200GS
The Veg
PostPost by: m750rider » Thu Sep 22, 2016 12:29 am
No, my own spare.
I'm sure r.d. enterprises or Dave Bean have rebuild kits
m750rider
PostPost by: pharriso » Thu Sep 22, 2016 12:37 am
I rebuilt mine with a kit from Ray
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: The Veg » Thu Sep 22, 2016 12:52 am
I meant the same type that Mark listed, as in exactly what would be needed to de-servo a Plus 2?
2012 BMW R1200GS
The Veg
PostPost by: pharriso » Thu Sep 22, 2016 10:17 am
Ted Taylor appears to have one for sale as well - http://www.taylormadeclassiccars.com/parts.html
Master cylinder $75
Rebuild kit $39
Done!
Phil Harrison
PostPost by: The Veg » Wed Sep 28, 2016 4:47 pm
Bob, check your messages.
2012 BMW R1200GS
The Veg
PreviousNext
