Handbrake lever puzzle
Elanintheforest wrote:Geoff, this is ringing bells! When I bought The S2, it came with a Plus 2 as well! Both cars were completely apart, but I seem to remember that there was only one handbrake....and the S2 got it.
Pretty sure that they are identical, but as you say, you have to remove the brackets.
I do have other bits and pieces for the handbrake, also sourced from other Plus 2 cars, so any issues, do let me know.
Cheers..Mark
Hi Mark
Do you have any parts for the twist and pull type handbrake?
James
66 Elan fhc, 72 Elan Plus 2S 130/5, 98 Elise 2.0l Duratec
_____________________________________
Which way up should this be???
- jkatthehelm
In this case, the switch completes the hot wire to the light.. the other side of the lamp is grounded. If there were a ground tab on the switch it'd result in a short circuit. Conversely, the wire to the switch may be the ground wire completing the circuit to the lamp and the other side of the lamp goes to +12v
- Gettyselan
Users browsing this forum: No registered users and 43 guests
