Air in the brake system
So I sign up again. After returning from holiday, I have bled the Bremsystem with a Eezibleed device. With a pressure of 1.6 bar was still much to the air bleed screws on the rear calipers. I then repeated the procedure again the next day. Actually arrived at the front left brake caliper still little air out.
The brake pedal now has a good pressure point. The braking effect during the test drive was ok.
Apparently it was not possible to bleed the brake system with a vacuum device to 100%.
I hope the problem is solved and I thank you for your lively discussion.
greeting
Egbert
greeting
Egbert
elan+2s - First Gear
Users browsing this forum: richardcox_lotus and 13 guests
