Front brake overhaul question
mgourwcg wrote:I think the hydraulic pressure through the system is the same, at least on a single circuit system. The braking difference between front & rear is probably down to the design/sizing of the calipers & discs
Yes - that is correct. The pressure in the brake lines is the same so the clamping force on the disk is proportional to the area of the caliper pistons. The rear pistons are smaller and hence the braking is less.
- Higs
Whether single circuit or tandem master cylinder, the pressure is the same. The rear caliper pistons are smaller diameter than the front so the force on the rear pads is less by the ratio of the piston areas.
'67 S3 SE FHC
'67 S3 SE FHC
