Question for you tandem brake guys....
PostPost by: curly type 26 » Mon Sep 14, 2009 7:18 pm
Not something as simple as seized caliper pistons? Im sure you have checked them if not remove pads, lever pistons fully in & check free movement leave lever in position & pump brake till piston moves & traps lever. Push back again & refit pads. Are they correct pads? Good luck Curly :D
curly type 26
PostPost by: collins_dan » Mon Sep 14, 2009 7:48 pm
Chris,
I put Ray's stainless steel hoses on and they do make a difference in terms of feeling of firmness. Also, 2 are slightly shorter than the other 2. I think the shorter go on front. I think I figured out I had it wrong when one rear was fitting a lot tighter than the other. I would also recommend getting speedbleeders, makes bleeding the brakes by yourself really easy. If you decide to go that route, the size you need is SB3824L. Also, I got one for clutch slave cylinder as well.
Good Luck,
Dan
collins_dan
PostPost by: Frank Howard » Mon Sep 14, 2009 8:09 pm
patrics wrote:If there was two different size master cylinder pistons then the pressure would still be the same in each split.
Steve,
I respectfully disagree. First of all, in a tandem master, the pistons are two different sizes. As they both move the same distance, the larger piston pushes more fluid than the smaller one does. That creates more pressure.
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
PostPost by: paddy » Mon Sep 14, 2009 8:40 pm
Frank Howard wrote:I respectfully disagree. First of all, in a tandem master, the pistons are two different sizes. As they both move the same distance, the larger piston pushes more fluid than the smaller one does. That creates more pressure.
I'm going to respectfully disagree :) Since force = pressure x piston surface area , a smaller piston creates greater fluid pressure for a given pedal force.
At the caliper, the opposite is true: for a given fluid pressure, the force at the pad increases with a larger piston.
To think of it another way, the mechanical advantage of the system (ie force at the pad / force at pedal) is equal to the ratio of (caliper piston area / master piston area). So smaller master cylinder piston = greater force (at the expense of greater pedal travel).
Paddy
1963 Elan S1
paddy
PostPost by: johnsimister » Mon Sep 14, 2009 9:51 pm
Paddy is right.
johnsimister
PostPost by: Frank Howard » Mon Sep 14, 2009 10:09 pm
Paddy, you are right. What was I thinking? I should know because when I removed my servos from my Europa, I had to go to a smaller diameter master to increase the pressure in order to make up for the lack of assist. Duh.
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
PostPost by: Chrisrich » Tue Sep 15, 2009 1:01 am
Thanks everyone.
Dan, I just ordered those speed bleeders.
I should get the new lines by tomorrow -- we'll see what gives.
(PS: yes, Curley, I did rebuild the calipers, and they act pretty much as you describe. The pads are the standard street pads that RD sells.....)
1970 Elan S4 DHC 45/9780 1972 Triumph TR6
1958 Bugeye Sprite 1967 Triumph Trophy 650
1991 Ducati 900ss 1989 Honda GB500
Chrisrich
PostPost by: ecamiel » Tue Sep 15, 2009 1:24 pm
Do the simple things first.
Raise the front of the car and re bleed the master cylinder. Then re bleed the brakes befor you get into everything else. It worked for me.
Eric
64 S1 with S4 dual Master
ecamiel
PostPost by: curly type 26 » Tue Sep 15, 2009 1:25 pm
Cheers Rich i just had to check as they can give those symptons, if one piston moves & one does not. Also had it with crap pads. good luck Curly :lol:
curly type 26
PostPost by: patrics » Tue Sep 15, 2009 5:13 pm
Gents,
I?ll still disagree and say that I am correct that both pressures will be the same.
A step bore m/cyl is used to give more pressure in the failed state for a given pedal effort to pass regulations but in normal usage it would be the same.
So how about this
Piston diameter A = 25.4 (Primary)
Piston diameter B = 20.6 (Secondary)
Input force 1200N (300N @ 4:1 pedal ratio)
Pressure = force / Area
Primary pressure = 1200 / 506.71
= 2.368 N/mm2 or 23.68 bar
Force on secondary = 2.368*333.29
= 789.23 N
So output pressure secondary = 789.23 / 333.29
In the failed state the secondary pressure would be:
1200 / 333.29 = 3.6 N/mm2 or 36 bar
In reality because a master cylinder doesn?t have a simultaneous cut off then the secondary could be a few bar lower.
Good enough?
Best Regards
patrics
PostPost by: Chrisrich » Wed Sep 16, 2009 2:44 am
Well, these aeroquip lines are an improvement, but I don't think I've got this problem beat yet.
I've lost much of the spongy-ness, and there certainly is a more consistent pedal. Breaking effectiveness is better, but still feels week, i.e., still cannot lock up the wheels.
After thrashing it about and pulling into the garage, I'm measuring 105 degrees (f) at the rear and 85 at the front, both sides. This just sounds wrong to me, and surprisingly low all around, no?
Chrisrich
PostPost by: chicagojeff » Wed Sep 16, 2009 3:14 am
Dear all,
2 comments. First, when you say you are getting less braking force than you think you should have, did you say what pads you were using? Just a thought that you can get the car to skid or chirp with uprated pads, even with less than optimal pressure in the lines, so maybe describe more how your pedal feel is?
Second, the polite and informative disagreement on this thread just reminds me how much I love this owners group. No flaming, no bullsh**. Respectful teaching and learning. It really is part of why I own an Elan. Thank you all.
Jeff Who Must Soon Put His Car Away For the Long 8 Month Chicago Winter
67 S3 DHC
chicagojeff
PostPost by: Chrisrich » Wed Sep 16, 2009 3:34 am
Agreed. Well said.
As to my pedal, it's hard to describe. In and of itself, it's not bad. While not the most solid pedal I've felt, there's plenty of meat to it. Probably drops 1/4 before it comes on. If I threshold brake, i.e., full-on from 50mph, I probably get 3/4 of the way down, but never to the floor, for instance. Like I said, the stopping power is improved, and is probably even usable as is, but it just doesn't have that bite. The pads are called Classic Gold. I don't know if they make more than one type of pad. I got them from Ray at RD. I bled the master (i.e, cracking the 2 output bolts while pushing down on the pedal), and I had no problem bleeding all the lines.
I'm wondering if I should try to switch the lines, to feed the front brakes from the rear of the master.
Chrisrich
PostPost by: paddy » Wed Sep 16, 2009 7:37 am
In reply to Steve (patrics) comment: you may well be right. I've never looked at how these tandem cylinders work, but I know it's not as simple as two independent pistons on two independent circuits just fixed to the same pushrod so they always travel the same distance. (If it worked like that, then the pedal would stop moving as soon as one of the circuits had moved as far as it will go, leaving no pressure in the other one.) My point was just about the relationship between piston size and pressure.
As for the step-bore cylinder I thought that was something different, ie a master cylinder that displaced a large fluid volume for the first part of the pedal travel (to move the pads into contact with the discs) and then a smaller piston for the later part of the travel to maximise the braking pressure.
In relation to Chris' problem have you thought of going down to your local friendly MOT centre and getting them to put the car on the brake testing rollers so you can get an accurate measurement of the brake performance front and back? At least then you'd have a clear idea of what you're dealing with. I don't have the numbers but I'm sure someone here will have the data from their last MOT to tell you what the expected efficiency should be.
Paddy
1963 Elan S1
paddy
PostPost by: collins_dan » Wed Sep 16, 2009 1:15 pm
Chris, You could run new lines just in the front, as the factory set up was unnecessarily long on federal cars, going from master to right side, then splitting to the right front tire and then back across to the left front tire. If you routed it from master to splitter to left front and right front, you would reduce the length of line by about half. Dan
collins_dan
PreviousNext
