Tandem Master Cylinder
• Page 2 of 4 • 1, 2, 3, 4
Eric,
That's brilliant! I'm leaning toward getting the AP Racing cylinder from Caterham cars as it's not easy to find someone dealing in Girling parts. AP part is CP6093 I think. Caterham calls it part number 77176. I've sent an e-mail to confirm dimensions and that it has a remote reservoir capability.
'67 S3 SE FHC
'67 S3 SE FHC
In addition to my initial posting, I just stumbled across some pictures that show how I installed remote reservoirs in my S4.
OK no twin cam in sight but the available space situation beneath & behind the Webers presented the same situation that you're dealing with.
I think you will also find ample space on the bulkhead above the passenger footwell.
Beware of the Illuminati
there is a nissan f10 master cylinder I use on my Europa -----no pn though ---ed
Johan,
Are you still happy with the Caterham tandem master cylinder? Is there enough clearance under the carbs to take the M/C cap off to check brake fluid level? Was it necessary to fit the proportioning valve to the rear brakes?
Colin.
Colin.
sotul86 wrote:Hi
I?ve a tandem cylinder from a caterham it works lovely....planning to upgrade to +2 brakes in front but it woorks great even without them, also have a brake proportian valve for the brakes in the back. the cylinder is (Dual brake master cylinder Girling 74066147, parallel bore 11/16")
'68 S4 DHC
- fatboyoz
Get the version with the remote reservoir. It's easier to keep an eye on the level and to top up when/if necessary. Very happy with my setup. I didn't use a proportioning valve as the mc bore is the same as original.
'67 S3 SE FHC
'67 S3 SE FHC
Hi Jim
Tandem cylinder fitted to S4, car still not on the road - currently fitting 26R arches. Engine not in so still to find out how easy to top up master cylinder, but resovoir is plastic so should be able to check more easily. Not intending to fit a servo - I have run Elans without before, I did buy a new servo thats sitting on the shelf, but would need two for a tandem system. I have got EBC groved disks and EBC pads, which are recommended by several people on the forum, I've used EBC pads before on another car and they seemed good, although squealed a bit.
Regards Gray
Regards Gray
- Gray
After much procrastination on my part, I have finally accepted the advice of fellow Elan owners.
I've decided to dispense with my brake servo and fit a tandem master cylinder (with 11/16 bore).
So, all I've got to do in the first instance is buy the master cylinder-should be a piece of cake after reading all the previous postings I thought. WRONG!
The chap at Classicar Automotive has been trying for several days to get me one without success. He says that the supply seems to have dried up very recently and he 'has hit a brick wall' at AP Racing. The one Tony Thompson supplies has a 13/16 bore and this is the same one that Caterham sell (part no 77176) as supplied by AP Racing.
"And so they rang the Electricity Board"
Has anyone got any suggestions for other sources?
Jim
Jim
Always grateful for advice.
- FOX5D
Caterham Cars.
The AP p/n is CP5615-2PRM100 unit (with reservoir) and the CP5615-3PRM100 unit (with elbows to suit a remote reservoir). The -3 is what you are basically looking for.
I believe it is made for Caterham so it should be available as a spare. It has a 0.70 inch bore. Ask them if it's Caterham part p/n 30B006A. Certainly looks like the one I installed on my S3. This one seems to be with reservoir but I'm sure you can take it off, get the elbow fittings, and mount remote reservoir(s).
'67 S3 SE FHC
'67 S3 SE FHC
Thanks Bill
My preference is for an mc with integral reservoir (even if it is a bit fiddly to top up). But looking at your picture (attached), I'm not sure whether the reservoir might be too tall to fit under the carbs? Could you measure the height of it please?
Jim
Jim
- Attachments
- PA220013small.jpg (38.17 KiB) Viewed 2497 times
- FOX5D
Looks like only heavy duty industrial stuff on their website David.
Bill: I just searched for p/n 30b006a on the Caterham site, and it brought up their standard mc 2007 onwards (see below). This looks like just what I want with a nice flat reservoir. But, when I spoke to Caterham earlier today, they told me that the bore was 10/16 (0.625) not 11/16 (0.7).
I also tried the AP number on their website but the search brought up nothing.
So I will check with both of them tomorrow.
Jim
Jim
- Attachments
- 3282-3256-large.jpg (10.52 KiB) Viewed 2493 times
- FOX5D
