R/h side indicator rhd +2s 130/5
Hi chaps, has anyone had a problem selecting the right turn indicator (ie not working, new flasher unit fitted)perfectly ok when selecting the left hand side and hazards all work when using the hazard switch.Regards Steve
72 Elan +2S 130/5
- Steve Brooks
Hi Steve,check the multi block lucar connector around the steering column,the wiring from the indicator switch joins there,get a multimeter or test lamp and have a poke about,if you have a workshop manual you can test the correct wires for power etc from the diagram,good luck
Phil
Phil
- p.faurie
