Lotus Elan
Wanted early Lucas indicator stalk 35605B
PostPost by: Peter +2 » Fri Nov 01, 2024 6:27 pm
Evening all,
Does anybody have a good working spare Lucas indicator stalk 35605B?
This is for an early +2 (non collapsable steering column) with the horn button on the indicator stalk see pictures.
If anybody has or know where to source one I would be really grateful.
Here are a few pictures.
IMG_6399.jpg and
IMG_6398.jpg and
Many thanks in advance
Peter
1968 +2 BRM
Peter +2
PostPost by: alan.barker » Fri Nov 01, 2024 6:53 pm
I had a 1968 +2 and i thought it was Ford.
PostPost by: ncm » Fri Nov 01, 2024 9:30 pm
Cortina Mk 1+2 used a similar stalk that can be used on the +2. The Lucas item fitted to my early +2 does not have the option to pull the stalk towards the steering wheel to operate a headlight flash function that the Ford branded item that I have from a Mk1 Gt has. Be aware that the Corsair item, although visually similar, does not have the horn push on the end of the stalk...
Brian.
PostPost by: Peter +2 » Sat Nov 02, 2024 8:44 am
Thanks & much appreciated your responses as there are so many similar stalks.
I researched Ford parts suppliers on line with no luck but found these two BL options:
Classic Mini Indicator Stalk Column Switch Lucas 39384 SQB168 119SA 13H7779
https://www.ebay.co.uk/itm/322670236121
_skw=lucas+indicator+stalk+119+sa&epid=23017021710&itmmeta=01JBNZYFTJXDH3H5NDAJ24TBDJ&hash=item4b20a511d9:g:wAEAAOSwmiVmueTb&itmprp=enc%3AAQAJAAAA4HoV3kP08IDx%2BKZ9MfhVJKng84tnTLKpdkUd7HX%2BUTBgYrw5i5vsAENmg%2BCHjFVBCTe55zn0VSxR6huX173qvffXeleQ7HHFyniJEktz4qJ76OnVwXUSy5TVlatASS8dZkLksGklLCiMx7XJM0zYjhYo6k%2BN6pp2mSClHsZe18SLnopWtp23WFoycxURsmMBxBQY7oZgTg%2BTeWDMHohnxOeC%2B7FiI%2BWbpOK9ljKl0LQ7oKVGrIMZenmKHkHMOZ97SZabtqa3HXSOJjLu6NRLU88w8E5AfeLEmFTRv2FLsCtZ%7Ctkp%3ABk9SR879-b_dZA
Apart from dissapointly missing the chrome horn button it has 9 poles and hopefully will fit in the ford column shroud.
Alternatively this one which looks functional but a little beat up:
https://www.ebay.co.uk/itm/276632164852 ... R9qD1ZLdZA
Peter
1968 +2 BRM
Peter +2
PostPost by: oatk » Mon Nov 04, 2024 10:08 am
Car Builder Solutions sell a compatible stalk for the early type:
https://www.carbuilder.com/products/ind ... mbly-black
It's a little flimsier than the Lucas one, and the cable tails need re-ending as bullets (and I think one re-joined half way) but it's been working fine for a few years now in my '67 +2. The longer cables were easier to route through the binnacle with plenty of slack. You may also need to bend the stalk slightly in a vice to make it match the original.
oatk
New-tral
PostPost by: Peter +2 » Tue Nov 05, 2024 1:47 pm
oatk wrote:Car Builder Solutions sell a compatible stalk for the early type:
https://www.carbuilder.com/products/ind ... mbly-black.
Many thanks for this suggestion, I had actually already pressed the button and ordered the one for a Mini which hopefully arrives later this week. I will report back later as whether that was a good decision or not.
Peter.
1968 +2 BRM
Peter +2
