Door Lock Rod Clips
My drivers door would not open from the inside and I had to lower the window and open from the outside a minor panicky moment. After removing the door card I could see the problem immediately, the plastic part of the door rod clip had disintegrated and the rod had slipped out. A simple fix just get some new rod clips all our lotus suppliers had them on their web sites from £1.60 to $4.60 each. I ordered 2 They came they didn't fit the plastic part was 6mm the hole in my door lock 5mm.
I did this 5 more times Each time the result was the same. I eventually found out that they were Land Rover clips.
By this time I had spent £70 on parts packing and VAT. The pictures on the websites all showed lotus parts but all supplied Land Rover parts please see attached Photo.
My 8th attempt was successful and I would like to give a shout out to SJ Sports Cars who had replicas made the correct size
All fitted and working without having to drill bigger holes in the door lock
- pete.chiswell
I had a similar problem with clips from RD Enterprises.
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
Presumably these clips were not Metric sized back in the day? So if you have any originals lying around don't lose them!
I know I got bitten when I purchased a couple of new rods some years ago. (If I remember correctly) they were 1/8" diameter but the correct size is 9/64". The original clips couldn't deal with the smaller diameter....
Nick
Nick
elanner - Fourth Gear
