Is this an early + 2 steering column?
Hi There
As per title, is this an early + 2 steering column? Does anyone have a pic that shows the clamp arrangement please? I have so many parts in so many boxes (from 3 cars) that I have not got a clue anout anything anymore!
There is no lower support, is that right?
Pics below.....Many thanks
Berni
Berni
berni29 - Fourth Gear
Yes, an early column.
See photos below for bracket which fits to the 2 long bolts shown in your photos, with several flat spacers in between, to ensure that the switch ‘binnacle’ doesn’t touch the dashboard.
If you don’t have a workshop manual, you need to get one.
No support at bottom, but there is a sealing plate to the bulkhead.
Click on photos to enlarge.
- Lotusian
Hello
Thank you. That really helps. Now I just have to find the parts.
I had a workshop manual until recently but unfortunately the container it was in got flooded and I did not notice for a while......
Must get another as you say.
All the best
Berni
All the best
Berni
Actually have just found another copy of the workshop manual. Thats what happens when you have 3 plus 2's
Tks
Berni
Tks
Berni
Hi Berni,
That doesn't look quite right to me.You appear to be missing the bracket at the top of the outer column that the indicator/headlight switch fastens on to.
Here's pictures of the column from my early car (Jan 68).
Note that the indicator cancelling cam fits lower down on the splined section.
- ncm
