Lotus Elan
Plus 2 dash wiring diagram and layout.......
PostPost by: berni29 » Sat Jul 27, 2024 9:23 pm
Hi Guys
Just rewiring the dash, does anyone have a wiring diagram and layout for an early plus 2 please. Also wire colour/identification for the indicator switch assy. Ours has 9 wires.
Many thanks
Berni
berni29
PostPost by: Jens Jeppsson » Sun Jul 28, 2024 11:01 am
Hi Berni
Perhaps hou'll find what you need in this thread:
viewtopic.php?f=51&t=45167
/Jens
Jens Jeppsson
First Gear
First Gear
PostPost by: berni29 » Sun Jul 28, 2024 8:09 pm
Thank you those are helpful. I had a good search on the net but did not see that post.
All the best
Berni
berni29
PostPost by: ncm » Mon Jul 29, 2024 7:44 pm
Hi Berni,
Your switch has 9 wires but only 8 are used in the Plus 2 . There is no connection to the white wire as this is used to supply power for headlamp flash in the Ford application.
Brian.
PostPost by: berni29 » Mon Jul 29, 2024 8:58 pm
Hi Brian
Thank you, but how does it flash if the flash wire is not used? Apologies for my ignorance!
Thanks again
Berni
berni29
PostPost by: ncm » Mon Jul 29, 2024 9:20 pm
Hi Berni,
The early cars were wired with a system that operated using a 'headlamp flasher micro switch, a headlamp flasher unit and a relay' that operated if the headlamp vacuum switch was pulled when the light switch was off......
Have a look at the top right corner of the wiring diagram for the details of how it all worked..
Brian.
PostPost by: ncm » Mon Jul 29, 2024 9:27 pm
Here you go :-
Screenshot_29-7-2024_222454_.jpeg and
and a scan of the owners manual :-
IMG.jpg and
