Speedo, Rev Counter warning light snoot/shroud
Hi Guys
As per the thread title, the Rev and Speedo both have plastic inserts that stop light spill on the ignition, main beam and indicator lights that are in the instruments.
Does anyone know the official names for these inserts and where to get them please?
Mr Google was not much use in this.
All the best
Berni
All the best
Berni
berni29 - Fourth Gear
Is this what you mean ?
https://www.ebay.co.uk/itm/134564236789
Possibly also obtainable from Speedy Cables who repair and restore Smiths instruments:-
[email protected]" target="_blank
S4 DHC
S4 DHC
- oldelanman
Thank you but sadly not. I did see those on ebay when I was searching though. None of my rev counters or speedo's have that type.
Here is a picture of what I am looking for.
All the best
Berni
All the best
Berni
There are different types, there can be 0/1/2 metal connectors down the sides , pictured has 2.
May have some in the shed, how many connectors do you need?
P.S. there should also be a small piece of rubber tube on the " jewel" to connect to the end of the fitting..
Hello John
I am short of 4 in total, with 3 being required sooner rather than later.
If you have them how much would you require to part with them +postage?
By the way do you know the official name for these things?
Many thanks
Berni
Many thanks
Berni
I'll have a look in the morning and see what I have....
Found some, the rubber pieces as I remember were all perished and stuck to the jewels, I also seem to remember some of the metal clips having extensions on to contact the body of the bulb holder , thereby earthing the bulbholder body...when used on the wrong bulb ( ignition warning ) can cause problems so later done away with in favour of proper wiring...
Have as below
Three with metal pieces
Three metal pieces
Ten holders
Just make me an offer and they're yours
Have as below
Three metal pieces
Ten holders
Hello
Brilliant, will PM you thanks!
Berni
Berni
I recently refurbished my instruments, brought about by a failed speedometer (so I decided to clean up all the instruments).
The rubber bit at the end of my light tubes were all missing. I found some small rubber grommets to fit the end of the tube, that were a snug fit with the jewel and the tube. I held these on the tube with a small amount of flexible glue after positioning them correctly.
My instruments and in particular their lights are fanstastic now, much brighter than they were before fixing, also helped by replacing the bulbs with LED ones.
Skittle. 1967 Elan S3 DHC
- skelteanema
