Break Tandem Master Cyl Rubber Seal
I am so happy to have found a new Reservoir including the 2 Rubber Seals for the Break Tandem Master Cylinder of my +2S 130. But now the Question:
In which direction should the rubber seal be fitted on the nose of the reservoir?
Version A or Version B, and why (i always like to understand what i do)
Hanspeter
Elan +2 S130 1971 Pistachio Lime Green
hastu - Second Gear
Congratulation on such a find (esp. the rubber front seal, I had to make do with a couple o-rings after some trials): I would think AAAAA but would first test fit the seal it in the master cylinder to see how it sits at the bottom, then measure how much of it would be pressed in when the reservoir is inserted till the c-clip is inside its groove. If it looks like there will be some mechanical pressure that should be good (the seal is only at atmospheric pressure, one just need it not to let the brake fluid seep away over time).
S4SE 36/8198
nmauduit - Coveted Fifth Gear
