weeps - gearbox and diff
Hi. I have 2 leaks that were identified in a mechanical inspection when first buying my '68 +2 a few months ago.
I was told that they are nothing to worry about, but they are annoying now as I don't like having leaks on the floor, especially when I can't fill them back up!!
1 leak is in the rear gearbox seal and 2 leak is the n/s diff drive shaft seal.
I have not much inclanation to get under the car, and not much skill and fixing big stuff, but I can do the basics.
Arte these leaks easy to repair, or should I take it to a mechanic, and what sort of price would I be looking at?
Thanks for your help.
- Marcus+2
Welcome to the forum and +2 ownership!
There are two things to bear in mind owning an old classic Lotus
1.All these old classic Lotus's seem to leak oil from one place or another and the cheapest solution would be to buy or make a drip tray to sit underneath your car.
2.If you are not going to get involved mechanically in your +2 ownership yourself and 'have a go' things can and will get rather expensive. Owning a classic Lotus and farming out work needed is not going to be cheap!
Having said that...
You have identified where the leaks are coming from so I will try and explain what is involved.
The n/s diff output shaft seal can be changed with the diff in situ but it entails removing the driveshaft and the drive joints be they Rotoflex or CV and then removing diff output shaft. It is quite labour intensive and not a nice thing to change but perfectly doable at home yourself depending on your skill set and tools that you have.
The tricky one is the gearbox extension housing oil seal.
Some say they have changed them with the gearbox still in the car and worked through the small transmission tunnel oil filler bung hole. But that depends if you find you can remove the prop shaft without removing the gearbox. Again, some say you can do it this way but I am sceptical.
Personally not having tried on a +2 I am not myself convinced that it can be successfully done that way in which case you are looking at removing the engine and gearbox to change the seal. This of course is labour intensive if farmed out but not a difficult job to do at home if you have the tools.
So..
If you are still intent on paying to have this done my suggestion would be not to take the car to your local mechanic who probably won't have clue what he is doing on an old classic Lotus but instead find a classic Lotus specialist and get some proper quotes, but be prepared for a large bill.
My real advice would be buy some new overalls and to have a go yourself. This is a good and knowledgable forum and we will all no doubt chip in and help you through the trials and tribulations of your +2 ownership.
Hope this helps, and good luck. Keep us posted.
Having said that...
So..
'71 +2 S130/ 5speed Type9.
- alanr
Hi Marcus,
For the oil leak at the Gearbox i suggest you remove Propshaft first which is an easy job. Check the Welch Plug in the Propshaft UJ. This often is a cause of Oil leak from Gearbox.
- alan.barker
Personally speaking if they are the only issues you have after several months ownership of a newly acquired classic Lotus I'd be cracking open the champagne. Congratulations - you've done well.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
2cams70 wrote:Personally speaking if they are the only issues you have after several months ownership of a newly acquired classic Lotus I'd be cracking open the champagne. Congratulations - you've done well.
I wish, my friend - I've got War and Peace listed here!!
![Embarassed :oops:](https://lotuselan.net/forums/images/smilies/icon_redface.gif)
![Crying or Very sad :cry:](https://lotuselan.net/forums/images/smilies/icon_cry.gif)
![Very Happy :D](https://lotuselan.net/forums/images/smilies/icon_biggrin.gif)
- Marcus+2
Hi Marcus,
I had exactly the same issue last year, please see finding.
Firstly the Welch/ core plug was missing this can be checked through inspection hatch in transmission tunnel from inside car with centre interior removed.
Please search Welch plug ( in Gearbox section)and you will see my findings and solution.
Also at the time I found I had spacers missing on gearbox mount which in turn angled tail end of gearbox towards ground slightly… or enough to help loss of some oil.
I never needed to remove tail seal thankfully and all has been fine since.
If you need to remove prop shaft it will come out through front engine side, just undo gearbox mounts and carefully place jack and wood under gearbox and raise slightly, a little awkward but doable.
That said this was all done with car raised 2ft off ground
The is great posts on here, the search is the thing
Jason
Jason
- JasonJ
With time and miles, the seal will wear a groove in the driveshaft nose. They are available.
Output shafts on early cars are subject to failure, so removing them to check condition and type is not a bad idea.
The inner seals are a stock item, the bearings are common also.
If the output shafts are of the 'necked down' type they can fail, so ought to be replaced, but if you don't drive like me, they might last quite a while.
- gus
