Original Jack and jacking points
Hi all hope your well
Just a random does any one have a original jack for a Elan plus 2 ?
Also the jacking points on the plus 2 that are under the door and just before the rear wheel. I heard they lead on to a lattice frame is this true ?
Does this mean when you lift all the weight on on the 10mm pin or is it on the outer section of the hole as marked up
- Bowers41
The Lattice is the baby elan.
On +2 elans there is a sort of removable metal beam.
Sounds like you need a workshop manuel
- alan.barker
The jack engages with bobbins welded onto the side impact protection beams in the sills. See above picture.
Elan +2
Elise mk 1
Elise mk 1
- Donels
Amazing that you guys.
I was giving the wrong information from the lotus specialist i called prob just a miscommunication.
I have orders the workshop manual as well. great tip
- Bowers41
