relay location 68 Plus 2 SE
PostPost by: Marcus+2 » Tue Apr 23, 2024 10:13 am
Hi - I have recently bought a 68 Plus 2 that has a few issues.
The wiring has been "modified" sometime in the past, and various electrical equipment is not working correctly - horns, indicators, panel lights etc - and so I am looking to repair/replace as required.
I have a workshop manual which is nicely detailed, but it doesn't really show the specific location of, for example, the horn relay.
Has anyone got a diagram of where the relays/fuses are located please?
TIA :)
Marcus+2
First Gear
First Gear
PostPost by: jono » Tue Apr 23, 2024 1:14 pm
'68 Plus 2 - hope this helps :D
P1090773 (Copy).jpg and
PostPost by: andywatts » Tue Apr 23, 2024 4:05 pm
Fuse position on a 69 +2 S is as per the photos attached. Pre the 'S' model was slightly different, but the horn relay position was the same.
Fuses and relays 1.jpg and
Fuses and relays 2.jpg and
andywatts
First Gear
First Gear
PostPost by: The Veg » Tue Apr 23, 2024 5:37 pm
This should be the fuse box. Pull the plastic cover off.
P2FB.png and
2012 BMW R1200GS
The Veg
PostPost by: ncm » Tue Apr 23, 2024 9:04 pm
relays.jpg and
Relays are as follows:-
Red:- Headlamp flasher relay
Green:- Headlamp flasher
Blue:- Horn relay
Brian.
PostPost by: Marcus+2 » Wed Apr 24, 2024 11:04 am
Ah, that's great - thank you all very much. :)
Marcus+2
First Gear
First Gear
