+2 front suspension rebuilt
Hi looking for the collective wisdom.
One of the inner front wishbone bushes is shot on my +2. I am already running TT adjustable shocks with new springs. Will be using the car predominantly on the road.
Q1. For replacement wishbone bushes should I use the Sue Miller poly bushes? Hoping these aren’t too hard for our UK roads?
Q2. Whilst doing the above seems sensible to replace top ball joint and trunnion bushes?
Q3. Any other parts that I should consider whilst the wishbones are removed?
Thank you in advance.
1969 Lotus Elan +2 4 speed - Barn find and currently undergoing recommissioning.
1979 Lancia V6 Group B Rally Car
Johnny America - Second Gear
Not sure about wisdom but I'm glad to share some opinions based on long term ownership and a few rebuilds.
Q1 - I recently installed poly bushes throughout mostly because it seemed to be the thing to do. I cant say I've noticed much difference so no strong feelings either way. I think if I were doing it again I would go back to standard but I'm not losing sleep about it.
Q2 Yes it would seem sensible - I recently did just that. However as far as the top ball joint is concerned if your current ones are good I'd stick with them. I replaced mine with new items and in a thousand or two miles ( 6-9 months) the rubber seals had totally failed so I think good old ones may be better than new . It obviously makes sense to at least inspect the trunnions - not just the brass bit but check out the thread on the bottom of the upright for wear and corrosion - this can be a failure point . If it were me I think I would replace these. If you want to start a nice long thread going ask if you should use oil or grease in the trunnion
Q3 - The only thing I can think of is to check out the bushes and washers that connect the anti-roll-bar to the bottom of the shocks.
As I said just opinions and I guess you'll get more.
All the best
Baggy
All the best
Baggy
- Baggy2
Baggy2 wrote:Hi
All the best
Baggy
Thank you very helpful.
I agree about the upper ball joints:Older quality is better than the new stuff: I found no discernable play, so changed the rubber boots and drilled/tapped the cap to fit a 1/4 unf grease nipple for annual greasing: Will last the life of the car I think..
Tony
Tony
- TonyA
Users browsing this forum: shynsy and 25 guests
