How to mount Quarterlight Window
Seemingly simple, but still very tedious. I'm trying to fit my Quarterlight and just can't find the right way.
I have bought new rubbers, which are of course very hard. When I put the small window in on one side, it pops out on the other side. And in the end I also have to mount and screw the cross strut from below. Who has a trick on how best to do this? Do you also have to put a cord in the rubber lip?
Hanspeter
Elan +2 S130 1971 Pistachio Lime Green
hastu - Second Gear
I did this seven or eight year ago so the memory is somewhat dim but I remember it as being awful. I used parallel jawed wooden furniture clamps as my third hand. Lots of soapy water lubricant and as I remember I pulled it in with the clamp on the bottom of the glass and the top jaw on the frame at the apex of the glass. very slowly and with much trepidation. Once the glass was in I used another clamp to hold the bottom together to replace the screwed in frame. No pictures and this description is not the best but that is what I remember. I don't want to do it again. Gary.
- GLB
It is done. The solution was to pull the window frame together with a tensioning strap. With a lot of soapy water and a rubber mallet from below, it was possible to fit the window into the rubber. We had also inserted a cord so that we could pull the rubber lip neatly outwards. Many thanks for all your support
Hanspeter
hastu - Second Gear
Thank you for the update. Very useful. I plan to do mine when it stops raining… so some time in the future.
1969 Lotus Elan +2 4 speed - Barn find and currently undergoing recommissioning.
1979 Lancia V6 Group B Rally Car
Johnny America - First Gear
