driveshaft close to chassis
The shaft should be offset to that side a little since the diff's input is not in the centre. That said, the shaft should not touch the edge of that hole. I had a similar problem during my five-speed conversion but it was due to the propshaft shop using a tube that was too large when they made-up the shaft.
Assuming that the diff is properly mounted and the shaft is the correct size, that leaves the engine & transmission mounts, but even then, that's all at the other end of the shaft and shouldn't produce this much of an issue at the back end.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
Hi ncm
Do you have your torqe rods fited??
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
I had a professional Lotus mechanic fit a new Spyder chassis to my '71 Plus 2S over 20 years ago. However, the propshaft rubbed on the right side of the chassis when installed. The solution was to grind a small amount off the chassis to provide clearance.
Lee
Lee
Jackson, CA
- Harvey
Out of interest, I just had a look under my S2 elan, the gap on the LHS of the prop shaft is about an inch, and on the RHS the gap between prop and chassis tunnel web is about half an inch.
Live your dream-wear your passion.
http://elantrikbits.com/lotus-elan-blog/
- ceejay
Sorry my age related error of poor concentration
+2s130 1971
+2s130 1971
Thanks for all the replies. Sorry so long in getting back.Here are some comments on your suggestions:
No, torque rods are not fitted. Perhaps can gain a a few mm with those.
Thanks for pointing out my error on the wrong way bolts, I'll certainly take care of that.
I wish now that I'd paid attention to this detail when I removed the drive line.
Tom
Tom
- TomMull
At least I'm not alone. Here is another and looks like the same chassis.
https://classicmotorsports.com/project-cars/1964-lotus-elan/rebuilding-and-refurbishing-suspension-restoration/
Tom
Tom
- TomMull
