Thermostat housing fasteners
Looking at past posts, it was suggested to future proof the routine removabiluty of the thermostat housing by using 2 studs and nuts/ washers rather than as now, the fully threaded bolts/ washers; indeed this was allegedly factory practice on some cars
The thread is 5/16 unc and the fully threaded bolts are 7/8 inch long.
Does anyone know how long the threaded part of the stud that goes into the head needs to be, to bottom and a bit..?
Thx as ever...Tony
Thx as ever...Tony
- TonyA
Always used standard screws no problem.
They don't need to be very tight.
Just check flatness of flange.
You can put some copperslip on threads, why not.
- alan.barker
I believe the bolt penetrate into the water chamber in the housing, so likely need studs to be 3/8 to 1/2" below the surface. So would guess you want a stud around 1 1/4" long.
- mbell
Just checked a head and the holes appear to “bottom” at approx 16.6mm deep and don’t go into the water jacket on the head I checked.
Fantastic...! have already made a pair of two ended 5/16 unc studs provisionally about 1.75 inches long from A2 stainless round bar..now to trim each end : one to the head depth as you have kindly determined, the other to housing + nut+ washer height....Thx..Tony
- TonyA
Hi Tony.
I think you should be careful using stainless steel in Aluminium. They are a long way apart on the galvanic scale and in the presence of moisture can cause corrosion. I believe It is possible to use stainless but it needs to be isolated with a barrier cream. Way back we used to use Lanolin on outboard motors but I think modern materials will be better now.
Ordinary steel bolts cause a lot less trouble.
Best of luck
Eric in Burnley
1967 S3SE DHC
Best of luck
Eric in Burnley
1967 S3SE DHC
- ericbushby
Hi Tony,
Why do you want to fit Studs
P.s. i know different subject but are you using Studs or Screws on the Exhaust Manifold
- alan.barker
Sometimes with a stud you can attempt to loosen the nut and the stud itself starts unscrewing, kind of negating the whole purpose for having a stud. This has happened to me with manifold and carb studs on the twin cam.
Perhaps cutting a screwdriver slot in the top of the stud would help keep it in place when loosening the nut?
1967 S3 FHC
1968 S4 FHC
1967 S3 FHC
1968 S4 FHC
- smo17003
My exhaust manifold is held traditionally; studs and copper nuts.
I put a screwdriver slot in the studs securing the thermostat housing on my Volvo Amazon 15 years ago.; likewise in the studs securing the air filter to the Zenith carb, exactly to have something to stop the stud backing out when loosening the securing nut: works a treat...Tony
- TonyA
Original is best. Corrosion may have been a problem when these cars were in the “banger” class with cooling systems filled with tap water but not now as well cared for classics. If you are concerned just use some pipe sealer or low strength Loctite to seal the threads to stop corrosion by keeping moisture and air out. As others have said not a good idea to use stainless steel.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Hi Tony,
I suggest to stay with Screws as original on Thermostat.
For the Exhaust Manifold Brass would be better
- alan.barker
lotusfan wrote:I also say stay with bolts. The BMC A,B and C series engines use studs for the thermostat housing and because of corrosion are always a pig to remove.
+1 i was just thinking of BMC Thermostats with Studs coroding solid, they were a real pain in the butt.
- alan.barker
have just found a galvanic table : sure enough, counterintuitively, plain steel is a better bedfellow with Aluminium than is Stainless. Also, zinc will corrode preferentially when in contact with Aluminium.
I will use zinc plated steel fully threaded bolts for the thermostat housing... as Alan, Rohan Eric et al have said all along..!
BTW, be careful : our precious Aluminium castings will fizz away if in contact with salty Platinum or Gold..!
Thanks all..Tony
Thanks all..Tony
- TonyA
Users browsing this forum: alan.barker and 4 guests
