How fast should the headlights go up and down?
PostPost by: hastu » Thu Feb 15, 2024 8:40 am
I have now installed all the vacuum parts of the Failsave in my +2S 130. When I start the engine, it takes several minutes for the lights to finally lower. After about 4 minutes they are completely down, is it normal that this takes so long?
When I switch the engine off, the lights are up again after 30 minutes at the latest. Several threads say that the vacuum should last up to 12 hours. Does this also apply if the engine has only been running for a short time, or does it have to have been running for longer beforehand?
Hanspeter
Elan +2 S130 1971 Pistachio Lime Green
hastu
PostPost by: Lotus fan » Thu Feb 15, 2024 9:45 am
You must have a leak somewhere.
Mine lower within 10 seconds of the engine starting, and can stay down for around 3 days.
Lotus fan
PostPost by: hastu » Thu Feb 15, 2024 9:49 am
Lotus fan wrote:You must have a leak somewhere.
So fast!!! I must really have a problem with a leak.
Many thanks
Hanspeter
hastu
PostPost by: hastu » Thu Feb 15, 2024 10:21 am
For Testing i have no Switch in the Pipes. Vacuum Pod, Pipes, Valve are all new. So the Leak can also only be in the Reservoir.
Or is it possible, that the Engine not deilver enough Vacuum??
IMG_7007.JPG and
Hanspeter
hastu
PostPost by: ericbushby » Thu Feb 15, 2024 10:49 am
There is usually a one way valve in the vacuum pipe from the manifold. You have not mentioned that, so is it OK.
Or there must be some air getting in somewhere.
Although mine is an Elan without the fail safe system the lamps rise in a few seconds and will hold for a few hours.
Eric in Burnley
1967 S3SE DHC
PostPost by: gus » Thu Feb 15, 2024 11:56 am
Have you tried driving the car? I had a vacuum check valve so tight that it would only open on trailing throttle. Lights would stay down for weeks though. With no reservoir
Do the lights move freely by hand? With no vacuum they should push down against spring pressure smoothly and pop up aggressively
gus
PostPost by: gus » Thu Feb 15, 2024 12:01 pm
Check all the joints
Try eliminating the reservoir
gus
PostPost by: gjz30075 » Thu Feb 15, 2024 1:36 pm
You don't show the switch in your diagram. On my failsafe Sprint, I found my oem switch leaking and
couldn't repair it so I adapted a Corvette switch and it works great, up and down,.
https://www.ebay.com/itm/154652004194?e ... R4Se0s-1Yw
I wanted it to look OEM so I adapted the switch to fit a Zephyr headlight switch so I can use the oem knob.
DSC03724.JPG and
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: Matt Elan » Thu Feb 15, 2024 2:44 pm
Mine go down quickly - in seconds - and then will stay down for hours when left with he engine off so it sounds like you have a leak. Do you have the separate vacuum solenoid and single 'pull down' unit?
Visit me on matthewvale.com
Matt Elan
PostPost by: pharriso » Thu Feb 15, 2024 3:22 pm
gjz30075 wrote:You don't show the switch in your diagram.
Greg, that's because he's eliminating the switch just to test everything else...
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: gus » Thu Feb 15, 2024 3:31 pm
Headlights should fly up.
Occurs to me now that without a switch, how are you testing?
If you are disconnecting the hose and allowing the entire system to come to atmosphere, then that might be the issue
It takes time for the reservoir to drain
With a vacuum switch properly installed, it vents only the vacuum pod, not the reservoir
So, until you get a switch try this:
run a loop up with a joint you can get at that is only going to the vacuum pod.
after the vacuum pulls the lights down, open that joint
The vacuum pod is now separate from the reservoir, and they should pop right up
Of course in this test the reservoir is also empty and the engine will rev up unless you clamp the hose off
gus
PostPost by: hastu » Thu Feb 15, 2024 4:25 pm
Thank you Guys for all your replies. I will test all this things over the WE
Hanspeter
hastu
PostPost by: andyelan » Thu Feb 15, 2024 7:15 pm
Hi There
From what you say, I would suggest that the most likely cause will be a leak in the chassis reservoir so try bypassing it.
On my car I ignore the reservoir and run the pipes directly to the vacuum pod. With this set-up the lights will stay down for weeks with the only downside is that, if they are lift in the up position, they can only be lowered once the engine is running.
Andy
andyelan
PostPost by: JimE » Fri Feb 16, 2024 9:15 pm
I have the stock factory failsafe on my 1974 + 2 and my headlights have always stayed permanently down when not in operation. JimE
JimE
PostPost by: gus » Fri Feb 16, 2024 11:17 pm
Well, since the headlights are held down by vacuum and up by springs, this seems really unlikely. A 74 would not be a Federal car, so are you sure have failsafe lights? With a heavy spring and new o ring in the original check valve, and no reservoir, it took about 2 months for my lights to come completely up with new actuator, and an electric solenoid, but when I bought the car, shutting the door caused the lights to make their first grunt
I had several years where the lights would stay down completely overnight, but that is best case with new components
gus
Next
Users browsing this forum: promotor and 33 guests
