What are this Holes for?
Maybe screws for rain guttering channel???
Hastu
The holes are for the fixing of the steel listing tubes that support the roof headlining. There should be four or five holes on each side of the car depending if the headlining requires four or five tubes - they do vary. These are not to be confused with the two pop rivets visible in your picture, that retain the interior light boxes.
I have included pictures of the tube pegs and their fixings for guidance.
Trust this helps.
Gary
Trust this helps.
Gary
Gary
1972 Elan +2 S130/5
2001 Elise S2
1972 Elan +2 S130/5
2001 Elise S2
- Gazzerb
Gazzerb wrote:Hastu
Trust this helps.
Gary
Thanks Gary, I thought the clips for the headlining were only screwed on from the inside, without holes on the outside. I have a headliner with 5 pipes. I will check if the 3 holes could fit.
Thank you very much
Hanspeter
Elan +2 S130 1971 Pistachio Lime Green
hastu - Second Gear
Hastu
It appears that perhaps your car has been repainted in the recent past and maybe the other two holes have been hidden with filler or paint.
Suggest you have a look from the inside of the roof where the original five holes should be visible.
In my Plus 2 door opening, there are four holes all at 7" centres. If you measure the centres of yours then work along checking with this value, they should be there!
Gary
Gary
Gary
1972 Elan +2 S130/5
2001 Elise S2
1972 Elan +2 S130/5
2001 Elise S2
- Gazzerb
Yes, there are 4 Holes on each side in the Door Frame, the 5th Mounting Point is inside the Car on top of the B-Pillar. This Mounting Points matches with the 5 Tube of the Sealing
Great, thank you all for your support
Hanspeter
hastu - Second Gear
Donels wrote:Gary,
Interesting that your picture shows screws. Mine were held in with pop rivets. I will soon be refitting the head lining, what have others used to secure the wires?
Dave
So were mine. On my last 2 Plus 2's I used cross head countersunk stainless set screws, M4, with a washer and nyloc on the other side. So much neater than the shonky pop rivets used by Lotus.
- jono
