Smith Heater Housing Rebuild
PostPost by: pudge2260 » Fri Jan 12, 2024 2:50 am
1970 Lotus +2-
Has anyone been able to pull the cable attachment lugs off of the air diverter dampers of the heater? I'm guessing that they are pressed into place.
pudge2260
First Gear
First Gear
PostPost by: JonB » Fri Jan 12, 2024 8:49 am
Yes, pressed.
Also, there made of pot metal so could snap if you’re not careful. Replacements are £50 IIRC from SJS. Ask how I know… :lol:
PostPost by: john.p.clegg » Fri Jan 12, 2024 8:56 am
Motorcycle chain link extractor.
John ;-)
PostPost by: jono » Fri Jan 12, 2024 9:01 am
..a pair of screwdriver blades and something for fulcrums under either side and lever them off against the casing. A little bit of heat will help too.
PostPost by: gus » Fri Jan 12, 2024 1:42 pm
It has been a very long time, but I don't think I took mine off. Put new foam on the hot/cold [err hot warm] door and new rubber on the floor vent door without really disassembling. Guess I pulled the box apart.
Having that floor vent as tight as you can get it is really important for defroster function. All the air goes down then up so if the floor vent leaks, no defrost
gus
PostPost by: john.p.clegg » Fri Jan 12, 2024 1:48 pm
Learn from my mistake, mark lever positions on the shafts and/or take a photos before disassembly..
John ;-)
PostPost by: pudge2260 » Fri Jan 12, 2024 2:26 pm
JonB wrote:Yes, pressed.
JonB, thanks for the smile today, I know the feeling. I will proceed carefully, pot metal pressed onto a steel shaft almost 54 years ago. What could go wrong.
pudge2260
First Gear
First Gear
PostPost by: JonB » Sat Jan 13, 2024 1:58 pm
Would like to say, I meant "they're", of course. In case my daughter is reading. Darned autocorrect....
