Plus2: tail and panel switch wiring route:
Hi, the I have a short (to earth) somewhere between the wire that goes to the tail light and to the Panel Switch from fuse #3 (mine is the 3 fusebox in engine bay version). Interestingly it blows the fuse when I engage the Sidelight
Switch when the panel light switch is in the "Instrument Lights Off " and "Neutral " positions, but ok when in the "Roof Lghts On" position . I see from the circuit diagram that there is a" branch (I guess a 1 into 2 bullet connector) somewhere between the firewall and the dash; providing one live to the Panel Switch and the other to the tail light. Does anyone know the path the red tail light/ Panel Switch wire from fuse 3 takes after it goes in a bundle thru the bulkhead and into the interior ..
I forgot to say, I separated this rogue red wire from its pair at fuse #3 that supplies the front sidelight, which is OK ..Thx in anticipation...Tony
- TonyA
Users browsing this forum: alleggerita, NTG999 and 32 guests
