New member
Hi everyone, new member to the forum having just purchased a 1969 Elan +2 for restoration. Looking to start my restoration next year once my current projects are finished. I’m a great believer in shared experiences and information via forums so will probably be posting lots of questions looking for guidance and advice etc.
My first question, what books/manuals would member’s recommend as good reference material for my project.
Look forward to any advice.
Finally a photo of the car
1969 Lotus Elan +2 4 speed - Barn find and currently undergoing recommissioning.
1979 Lancia V6 Group B Rally Car
Johnny America - First Gear
Welcome Johnny!
The original model-specific Lotus Work Shop Manual is a must-have, and the Parts Manual is a great resource for seeing what things should look like and how they go together. The online version of the Parts Manual at rdent.com will do if you have trouble getting a paper one. Beyond that, opinions differ about aftermarket shop manuals and such, but this forum is one of the very best resources for all sorts of wisdom for dealing with these cars.
Can't wait to see your progress!
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
Hi Both, thanks for the replies, ok I will search out the work shop manual. Is there a specific one for the +2 or is it covered in the Elan manual. Also assume the manuals are year/series specific eg S1, S2.
In answer to the run question. A quick play yesterday, good oil pressure, after cleaning the points I have a good spark. she is trying to run just needs some fresh fuel I think(hope).
The one you want is specific to a +2, is loose leaf, and has a white pvc cover
https://www.ebay.co.uk/itm/296097547965 ... R-a0s4WLYw
Previous :-
Elan S3 DHC SE SS 1968,
Elan S3 DHC S/E 1966
Elan S3 FHC Pre-Airflow 1966
Previous :-
- elans3
elans3 wrote:The one you want is specific to a +2, is loose leaf, and has a white pvc cover
<a class="vglnk" href="https://www.ebay.co.uk/itm/296097547965?
@elans3 thank you. Just checking the description of the item it says October 1972. My model is a S2 1969 is this still the correct manual. Thank you, sorry if this is an obvious answer.
J
@ elans3, perfect thank you. Purchased. ![Very Happy :D](https://lotuselan.net/forums/images/smilies/icon_biggrin.gif)
Printed off the parts list from this forum and made myself a folder. Workshop Manual arrived today, so all good to go.
So a quick update on my ‘barn find’ car purchased at auction last week.
Lotus have verified the car and a certificate of authenticity is on its way. Engine number matches so original.
Having check fluids etc, added a battery and fresh fuel and cleaning up the points she runs
good oil pressure and sounds sweet. The clutch was frozen on ( suspect due to being stored) managed to free this off so she now drives (although the clutch does feel heavy to me) more instigation needed.
As well as an ally rad and electric fan it looks like uprated coil over shocks all round see photo.
Drive shafts have also been replaced with twin UJ type.
To the chassis, so far all good, I can see that it’s been galvanised so clearly replaced at some point. There is no drain hole in the vacuum tank so am I correct in assuming it’s not a Spyder chassis??? Any help on how I identify the chassis would be appreciated. Photo of under the car looking up at one of the ‘Y’ arms alongside the gearbox.
Any general comments also welcome. Thank you.
Last edited by Johnny America on Sat Dec 16, 2023 10:51 pm, edited 1 time in total.
I'm really pleased the car is basically in sound condition, and that the engine is correct and runs well
Having had a look at the chassis myself at the auction, I am pretty sure (99%) it is a Lotus item. I reserve the right to be wrong though.
When I tried it I also noticed that the clutch pedal was a lot stiffer than I would have expected. I cannot remember about the brakes. I think the pedal may have been quite hard, but I could be thinking about the clutch. Neither of the master cylinder caps would come off with just my hands, so I cannot comment on the state of the fluid. You will know more by now.
Glad that you are having fun with he car. I will be playing with mine tomorrow. Just in the process of modifying the exhaust manifold so it works with a Zetec engine. One of MANY tasks.
All the best
Berni
All the best
Berni
berni29 - Fourth Gear
I had the same problem with the clutch on my Plus 2. Turned out to be the rubber flexible section of clutch pipe which was restricting the flow of fluid. Swapped the lot (bundy and flexi pipes) for a single braided line and all sorted. Clutch was also very "bitey", difficult to feather when pulling away. Solved by fitting a new friction plate.
JonB - Coveted Fifth Gear
Users browsing this forum: jimcast and 12 guests
