glove compartment restoration, '70 +2 federal
Putting the dash panel back together. The first thing that I've noticed is that there is no knob/ handle to open the glove compartment door and the door fits tight in the top left corner. Second, how is the actual box attached to the front wood gauge panel? The one that I'm working on is taped into place. Inside, no light or latch.
Descriptions and or pictures will be greatly appreciated.
- pudge2260
Later +2s have a push to open latch so there is no external handle.
- mikealdren
These are pictures of the glove compartment on my 1971 Plus2 s130 its a UK version so Federal might be different. The hinges are screwed into the side of the opening and to the back of the door so are essentially hidden when closed. The latch is a common device in the UK, used on loft hatches for example, and latches when the door is pushed in then unlatches when pushed again.
- rjaxe
It’s called a tutch latch. They are cheap as chips. Google it… you’ll be pleasantly surprised.
JonB - Coveted Fifth Gear
1970 +2 (fed)s have the handle, not the touch latch, as shown in the parts manual, Section BB -- Body - Facia (Early). Here's a photo of the hardware but, sadly, not installed.
The box originally screwed to the back of the facia with small wood screws with washers. On the top there is a crude flange that incorporates the slot for the lock. On mine I added a piece of light aluminum angel for additional support.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
[quote="Bud English"]1970 +2 (fed)s have the handle, not the touch latch, as shown in the parts manual, Section BB
My '70 fed non-S has the touch-latch and no light. And the latch doesn't work nearly as easily after having the dashboard apart for restoration. Have to give it a mighty poke to make it release!
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
The latch on my Plus 2S was always jamming, so I replaced it with a magnetic cupboard lock when I made up a new "drop down" glovebox.
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
Looks like the -2S's are totally different from the non-S's. Pudge, you've got options. It sounds like switching to a magnetic latch is better than the original. Maybe someone with a non-S can confirm if the mounting to the dash is the same as I've shown or different as well.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Bud English wrote:Looks like the -2S's are totally different from the non-S's. Pudge, you've got options. It sounds like switching to a magnetic latch is better than the original. Maybe someone with a non-S can confirm if the mounting to the dash is the same as I've shown or different as well.
Thanks for the pictures and info, enjoy the forum for everyone's help in solving these problems.
- pudge2260
Federal cars are not ever 'early' body
All the Federal 69-70 non S cars[4 small gauges, black window switches, labelled dash] I have ever seen have the touch latch.
Non Federal cars[thru early 69 registration, chrome window switches, external trunk lock] are pretty rare here
- gus
If any of you need a tutch latch Alan Thomas (Spyder fan) on here has a small supply of new ones which are complete with a nice set of fitting instructions.
elanfan1 - Coveted Fifth Gear
