Lotus Elan
rear brake caliper allingment
PostPost by: street » Sun Oct 08, 2023 7:54 am
Took car for test drive around the block, before i take it for compliance (in NZ), as part of the rebuild, i got new discs, cv driveshafts etc, fully along with fully overhauled rear suspension. When I installed everything i noticed that the discs appear to be slightly off centre, which meant i could only put slightly thinner pad on inside (toward diff) with thicker on outside (towards wheel). Everything felt very tight with no free wheeling on spinning up by hand.
I'm going to get car in the air over next few days, would shimming the calipers on inside of wheel bearing housing move then towards diff, thereby creating clearance.
Anyone experienced anything like this before.
street
PostPost by: vstibbard » Sun Oct 08, 2023 7:58 am
Did you fit the dust shield when replacing rear bearings?
Only thing I can think that would laterally change position if disk relative to calliper.
PostPost by: street » Sun Oct 08, 2023 8:03 am
Yes all fitted
street
PostPost by: street » Sun Oct 08, 2023 8:06 am
Are you saying the dust shield is sitting proud, thereby changing position
street
PostPost by: 512BB » Sun Oct 08, 2023 10:06 am
If the dirt shield is in place and the circlip is fitted correctly, that assembly is correct.
'When I installed everything i noticed that the discs appear to be slightly off centre'
Probably because one or more of the ears on the outer driveshaft / axle is bent, and the axle ears need to be trued up in a lathe.
Leslie
PostPost by: bitsobrits » Mon Oct 09, 2023 1:03 am
Sometimes they just need shimmed. Common on some makes. You can get shim washers from McMaster-Carr among others. While it's not absolutely critical to have the disc centered, it is desirable.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
bitsobrits
